Mercruiser ignition acting funny.... >
Old 07-21-2006 | 04:02 PM
TomZ's Avatar
Default Mercruiser ignition acting funny....
Top of the afternoon to everyone! Hope everyone has a great weekend out on the water!!
Question...
I'm having a strange problem with the starting/ignition circuit on my 383 (Merc Thunderbolt ignition). When I go to start her, she just turns over, but then as soon as I let go of the key (back to run) she fires and starts. I'm thinking that the starter solenoid might be going south (I bought a replacement), but I was wondering if maybe any of you had any insight into what could be going on.
I hope to be out on the Bay this weekend, but I'm hoping to have this solved first because though she does start now, something is on its way out and I'd rather not be stranded.
Thanks!
TomZ is offline
Old 07-21-2006 | 05:48 PM
GOODT's Avatar
Default Re: Mercruiser ignition acting funny....
There should be three terminals on the starter solinoid the one furthest from the block should have a wire going to the coil it is a by pass so that while you are cranking the coil still gets enough votage to start the mtr I would check that wire ( some mtrs do not have this )
GOODT is offline
Old 07-21-2006 | 07:37 PM
Dave_N's Avatar
That usually means low voltage at the coil. With the starter cranking the voltage is so low that you are getting very weal or no spark. When you release the key, the voltage jumps up, the spark gets much stronger and if the engine is still rotating fast enough, it may start.
It could be the battery, or a connection somewhere, but I betting if you check the voltage at the positive side of the coil during cranking, it will be low.
Dave
Dave_N is offline
Old 07-21-2006 | 07:40 PM
GOODT's Avatar
Dave
dave is right, that is why they used to use the outter terminal on the starter to power coil while cranking it is also used for electric fuel pumps for power before oil press builds enough for the press switch to take over
GOODT is offline
Old 07-22-2006 | 07:18 AM
TomZ's Avatar
I didn't think of the problem as being a low voltage condition. My starting battery is new/strong so it may be a bad connection that I'll have to diagnose. Fun fun!
TomZ is offline
Old 07-22-2006 | 07:22 AM
vandeano's Avatar
Dave
I would have to agree. Had same problem but with a street bike.
vandeano is offline
Old 07-24-2006 | 09:28 AM
Low voltage symptoms.
Check batter, wiring. Also, there's a good chance it could be some corrosion or poor contacts in the ignition switch itself. Had a similar problem, the key witch contacts were old/worn/corroded so much, it would not supply enough current for both solenoid and ignition while cranking.
Gary
rdoactive is offline
Old 07-24-2006 | 04:56 PM
TomZ's Avatar
Yeah, I'm going to clean up all the connections and see how it goes. The salt air really likes to screw with stuff I guess.
TomZ is offline
alecsammy
10
07-27-2009 12:30 AM
tontom1989mercv6
06-26-2005 10:48 AM
magnum
0
05-26-2005 07:15 PM
timucin
11-30-2003 05:14 PM
Jana
7
07-29-2002 09:29 PM
