5.7  2 barrel carb to 4 barrel >
Old 07-21-2006 | 10:25 PM
Default 5.7 2 barrel carb to 4 barrel
I have a 1996 Mercruiser 5.7 in with a 2 barrel, What manifold and 4 barrel switch out would you recommend? Will I gain anything? Thanks
boomer is offline
Old 07-21-2006 | 10:32 PM
Default Re: 5.7 2 barrel carb to 4 barrel
performer/peformer rpm/ air-gap/ eldelbrock marine carb you might gain a little
k24u is offline
Old 07-22-2006 | 03:48 PM
Thanks do you know it it requires an major changes?
boomer is offline
Old 07-23-2006 | 05:18 AM
Might get better response in the Tech section. Find the same carb that the 350 4 barrel uses and jet it the same to Merc specs and you should be fine.
BadDog is offline
Old 07-23-2006 | 03:12 PM
RPM Air gap and Holley 600cfm would be my choice.
Griff is offline
Bajapred
2
07-22-2007 08:22 PM
boomer
13
08-16-2006 02:24 PM
