pumping out holding tank >
Old 07-24-2006 | 11:19 AM
duksrule's Avatar
Registered User
Default pumping out holding tank
I had my holding tank pumped out for the first time sinse I have owned the boat and it didn't seem to empty it. The guy stuck sort of a shop vac nozzle to the side of the boat and let it rip. Should that have a line on it that goes down into the tank? Should I open the valve on the toilet? I want to make sure this thing gets emptied the right way.
duksrule is offline
Old 07-24-2006 | 12:07 PM
Ted G's Avatar
Default Re: pumping out holding tank
It should be plumbed so the hose from the fitting goes to the bottom of the tank in the boat. So when they put the sucker on it draws from the lowest point of the tank. To get a good pumpout you need to let them suck it dry, then rinse through the toilet with a gallon of water or so, then have them suck some more, this will get most of the nasty stuff out and leave mostly water in the very bottom of the tank, then make sure you use a deodorizer.
www.cbpba.com
Ted G is offline
Old 07-24-2006 | 12:51 PM
duksrule's Avatar
Registered User
I figured that the bone head was doing it wrong. He just used a suction on the side of the boat and that was it. I need to go somewhere else and have it done right.
duksrule is offline
Old 07-24-2006 | 01:19 PM
Ted G's Avatar
No that's the way it's done, your boat should be plumbed down to the bottom of the tank, just rinse before they stop sucking.
www.cbpba.com
Ted G is offline
Old 07-24-2006 | 01:30 PM
duksrule's Avatar
Registered User
Do I need to open the toilet valve or is the vent good enough to keep the tank from sucking flat from the vacuum? This is not something that I look forward to working on. Also how do you replace the vent?
duksrule is offline
Old 07-24-2006 | 01:41 PM
Ted G's Avatar
Vent should handle it. Should be a vent hose from the top of the tank to a hull fitting.
www.cbpba.com
Ted G is offline
never enuff
Do It Yourself, Boating on a Budget
2
07-24-2008 07:21 AM
never enuff
07-23-2008 07:19 PM
duksrule
1
07-26-2006 07:36 PM
Sight and Sound
4
07-05-2006 05:28 PM
Scott
Powerquest
8
07-19-2004 08:14 PM
