how can you tell a merc. labbed prop ? >
Old 07-26-2006 | 08:14 AM
26sonic's Avatar
Default how can you tell a merc. labbed prop ?
how can you distinguish a factory labbed merc. prop from a non labbed prop?
26sonic is offline
Old 07-26-2006 | 11:33 AM
throttleup's Avatar
Default Re: how can you tell a merc. labbed prop ?
Well there are several things to look for but thinner blades with sharper edges and a satin finish.
Julie
throttleup is offline
Old 07-26-2006 | 02:14 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile Re: how can you tell a merc. labbed prop ?
Look at the aft side of the prop hub under the nut. If there is a hand stamped group of letters and or numbers, it may be a Merc worked propeller. The letters and numbers are coded to tell small amounts of information. This doesn't tell if it was reworked by anyone else though. It just tells Mercury Racing has worked on it at one time. A trained set of eyes can tell if it is still a Merc Lab. If you need help determining more, give us a call with the code.
[email protected]
bbladesprops is offline
26sonic
Prop Talk
10
04-05-2011 10:03 AM
Schweeng
Prop Talk
2
06-22-2008 01:04 PM
26sonic
04-15-2007 03:08 PM
26sonic
Prop Talk
1
05-02-2006 09:45 AM
