cleaning a cockpit cover??? >
Old 07-27-2006 | 06:36 PM
t500hps's Avatar
21 and 42 footers
Default cleaning a cockpit cover???
How do you remove mildew on the inside of a Sunbrella cover? Is there some way to lay it out in the yard and scrub it? With what?
t500hps is offline
Old 07-27-2006 | 07:04 PM
Default Re: cleaning a cockpit cover???
Sounds drastic.....but Bleach and water do a great job, I use nothing else on mine
SUNSATION 25 is offline
Old 07-27-2006 | 07:46 PM
Try a solution of 60% water and 40% bleach to start. Let the solution soak in for 5-10 minutes and then scrub with a deck brush. First test in an inconspicious place. You can also purchase Mildew Stain Remover, but it is expensive, Approx. $12.00 at West Marine or Boaters World.
kjm5125 is offline
Old 07-27-2006 | 07:55 PM
Ted G's Avatar
Make sure you re-treat it with 303 waterproofer when you're done. Recommended by Sunbrella.
www.cbpba.com
Ted G is offline
Old 07-27-2006 | 09:18 PM
Reds Outlaw's Avatar
Be sure to wash in hot water before treatment or it won't work. I washed mine in the washer with detergent and it took almost all of it out but now have to rinse and treat .
Red
Reds Outlaw is offline
Old 07-27-2006 | 09:50 PM
Strip Poker 388's Avatar
Rob
Red
I haven't found a washing machine big enough to wash/rinse a 40 foot boat cover yet I use Woolite with a brush ,its mild and want leave a lot of soap residue
Strip Poker 388 is offline
Old 07-28-2006 | 01:03 AM
cuda's Avatar
I spread mine out on the driveway, used laundry detergent, a deck brush, and sprayed it off with a hose. Smelled good too.
cuda is offline
CULATER
Ft Myers Offshore
6
12-29-2007 09:07 AM
fatdaddy
Baja
2
05-11-2007 08:23 AM
Craney
04-03-2005 07:15 PM
ChevyThunder
Pantera
2
02-13-2003 07:07 PM
Jayl13
02-07-2003 07:15 AM
