Towing jetski or small boat behind your boat ?? >
Old 07-31-2006 | 03:28 PM
HiPerf2000's Avatar
Default Towing jetski or small boat behind your boat ??
Looking to occasionally tow a 13' cat the wieghs 600lbs behind my Sonic for when I'm rafted at the cove. It's about a 10 mile ride to the cove. I remember my parents trying to tow my 8' zodiak behind thier 30 cruiser and it never worked out well. Would fishtail and fall outside the wake.
What is the best way to do this ?
I was looking at this website. Anyone use this ?
http://www.towdster.com/main.html
HiPerf2000 is offline
Old 07-31-2006 | 06:13 PM
Default Re: Towing jetski or small boat behind your boat ??
If you lower the outboard down so it creates drag it will track in a line and tow it with a about 60 feet of line so it can,t get blown out of the wake in a crosswind and it will be alright.I used to tow a 21 inflatable behind my 28 Nordic parasail boat at 35mph for many years.
tommymonza is offline
Old 07-31-2006 | 06:39 PM
Ted G's Avatar
We had a setup like the toadster thing made from pvc, chain, and hooks, works fine. You could make one in about an hour for about 30 bucks worth of Home Depot stuff if you want to try it.
www.cbpba.com
Ted G is offline
Old 07-31-2006 | 07:09 PM
CAP071's Avatar
Just have the woman follow you up in the cat
CAP071 is offline
Old 08-01-2006 | 04:51 AM
Iggy's Avatar
Try using a line running from cleats on both sides of the transom back to the dingy in a "V" shape. That should keep it in the center of the wake.
Iggy is offline
Old 08-01-2006 | 03:21 PM
comp's Avatar
I have towed 2 jetskis behind our carver 396 and behind our top gun
I stagger the lines and set them back far enought that they ride inside the wake
we have never had a problem
comp is offline
oreo11zeus
2
03-19-2007 08:47 PM
MILD THUNDER
11-10-2005 09:16 AM
GregP
07-28-2003 12:50 PM
