525 SC Problems - Help!
Old 07-31-2006 | 07:00 PM
Exclamation 525 SC Problems - Help!
Hi guys,
I bought a 1995 38 Special (Baja) about two weeks ago. When I went on the sea trial with the guy the boat ran great. I guess it has some sort of intermitten problem that is driving me crazy. The one engine will run great and just die at any given time and then not start agian. I first thought it was loss of fuel but when I checked the carb and it seems to be getting fuel just fine. I then started to check out the the ignition system but I'm kinda lost. To tell you the truth I'm a noob to boat engines and could use some advice. Oh, one more thing. The engine will start just fine after it sits for 10-15 minutes. It's so odd.
Chris
sloppysally is offline
Old 07-31-2006 | 07:03 PM
Payton's Avatar
Charter Member #927
Default Re: 525 SC Problems - Help!
Sounds like a question in the tech section right now. Check out the coil.
Payton is offline
Old 07-31-2006 | 07:06 PM
CAP071's Avatar
sounds like a coil doesn't it. swap coils?
CAP071 is offline
Old 07-31-2006 | 07:10 PM
Yeah, I took the coil from the other engine and the problem didn't follow... I also replaced the pick up sensor on the distributor. That gave my engine about 2-300 more rpm (odd)than before but no fix on the stalling-
GOODT's Avatar
yes, sounds most likley the coil next time it happens feel the coil if hot thats your problem or you can try just swapping them as suggested.....you can do a resistance test but this is easier
GOODT is offline
Old 07-31-2006 | 07:20 PM
Ted G's Avatar
Watch the tach very carefully when it fails. If the tach drops VERY quickly or wobbles before the engine dies you likely have a bad ignition module. They will overheat internally and stop sending signal to the coil. Takes about 10-15 minutes to cool down and away you go.
www.cbpba.com
Ted G is offline
Old 07-31-2006 | 07:32 PM
When I watched the tach the needle "bobbed" like the engine was running out of gas or something. It would try to go back up a couple times then after that the engine goes dead -
Old 07-31-2006 | 07:35 PM
Ted G's Avatar
Swap the module or put in a new one, they're cheap.
www.cbpba.com
Ted G is offline
Old 07-31-2006 | 07:40 PM
Awesome - Is that the blue looking box near the dist? It is called Mercathode or something?
Old 07-31-2006 | 08:03 PM
Ted G's Avatar
Whoops, I take that back, I just looked it up. That sucker is expensive, swap them first to see if it's the problem.
An newer module will look like this one
And an older one looks like this
www.cbpba.com
Ted G is offline
