1996 baja 454 Mag losing power
I've got a 1996 Baja 272 with a 454 mag multi-port EFI, I lost about 10 mph in one day. Took the injectors out & had them flow tested & they checked out good. any other suggestions would be greatly appreciated
could be any number of things from a fuel filter to a dist cap ....ect
what else did you check before pulling the injectors ???????
did you check the fuel pressure at the rail ????
water separator ??????
ECT
ECT
ECT
are you running ethenol 10 fuel in your area ??????
ECT
ECT
ECT
Perform a cyl balance test or a compression test-sounds like you may be losing a cylinder. Also fuel pressure-seems like a lot of fuel pressure regulator problems this year-ethanol maybe????
ted
luv your " Spirtual adviser" thats what I need !!!!!!
as a matter of fact can you give me a call tomorrow theres something I need to run by you !!!!!! ( for real )
chevalcabre
American Offshore
9
06-16-2008 08:09 PM
