Awlgrip below waterline?
Old 08-01-2006 | 06:33 AM
resurrected's Avatar
Default Awlgrip below waterline?
I know where there is an old Formula 302 I can get CHEAP.... but it has been painted completely in Awlgrip. Is this good bad or otherwise?
Any info would be helpful.
Thanks,
resurrected is offline
Old 08-01-2006 | 07:21 AM
Audiofn's Avatar
Charter Member #232
Default Re: Awlgrip below waterline?
It is fine as long as you do not plan to leave it in the water for long periods of time. They will tell you no more then 3 days. Formula uses it for their graphics and there is a large part of that under water and it seems to last. The one thing that you do not know and that is MOST important is the prep work. If it was done correctly then it should be fine.
Jon
Put your best foot forward!
Audiofn is offline
Old 08-01-2006 | 10:52 AM
Thanks Jon, for my own personal use it would be in the water for 3-4 months. That is the response I kinda' thought I'd get, it's not cheap enough yet to re-gel the bottom.
Again, thanks.
Old 08-01-2006 | 03:04 PM
Remember Awlgrip is a brand of paint, within the brand are many types of paints. A generic class of epoxy such as a polyamide epoxy will survive for years under water but also chaulk quickly if exposed to sunlight, aliphatic urethanes depending on the type can survive up to a couple of weeks before blistering occurs ( depending on water temp and state of paint cure) certain blends of aliphatic polyesters will survive much longer underwater, other paints such as alkyds should Never be used underwater -
James is offline
Old 08-02-2006 | 10:32 AM
I have used AwlGrip below the waterline on sanded gel-coat and never had a problem. AwlGrip is the most recognised product from US Paints, but as James said, they make several products for different applications.
Gmoney52 is offline
Old 10-02-2006 | 05:16 AM
Thanks for the replies! I let it slide.... the next time I spoke to the owner he said it was painted with IMRON. I am in the middle of one major project, and I don't want another just yet!
Old 10-04-2006 | 10:45 PM
Imron and Awlgrip are both polyurethane based paint. Same durability.
jsmagnum is offline
Old 10-04-2006 | 10:55 PM
For whats it's worth, AwlGrip is a "true" polyureathane as it is mixed 1:1 with the activator. I would say the old Imron is comparable with it, but wouldn't go side by side with the new.
Gmoney52 is offline
entmanmd
Detailing, Painting, & Fiberglass
2
03-27-2008 05:30 PM
bouyhunter
18
09-08-2007 12:11 AM
Rambunctious
07-03-2007 07:41 AM
Danny_Ocean
7
03-26-2004 11:00 PM
bowtie89
08-05-2003 06:56 AM
