Go Back  Offshoreonly.com > Offshoreonly Marketplace > New Products and Member Discounts
The Largest Cmi Stocking Distributor >
Old 08-01-2006 | 12:06 PM
teaguecustommarine's Avatar
Offshoreonly Advertiser
Default The Largest Cmi Stocking Distributor
the proof is in the puddin, check out the inventory with more
on the way. From Big Tubes to Sport Tubes to E-Tops to 496, we have it in stock as well as tail pipes for stock bravo exits for Ilmor, Sport Tubes, and E-Tops. We can ship same day so make the call.
if you have any questions or need tail pipe build sheet for custom tails give me a call and i will fax you over everything you need to get the order in and made, OHH AND SINCE WE INSTALL EVERYTHING WE SELL, I HAVE TEST RESULTS IN FOR THE 496 MPH GAINS.
give me a call and let me know you saw it here on OSO
Attached Thumbnails The Largest Cmi Stocking Distributor-rs.jpg   The Largest Cmi Stocking Distributor-iv.jpg   The Largest Cmi Stocking Distributor-tv.jpg
teaguecustommarine is offline
Old 08-02-2006 | 10:34 AM
Default Re: The Largest Cmi Stocking Distributor
we have over 2 dozen big tubes in stock.
DOWN TURN and STREIGHT BACKS
Old 08-02-2006 | 03:48 PM
JUST IN 18pr of 496 kits
Old 08-23-2006 | 12:17 PM
just got back In stock now CMI MUFFLERS
Old 04-29-2007 | 02:23 PM
Still running any specials? The last time I priced CMI's for the 496 with the Corsa setup I was told it wouldn't work in a Baja due to the configuration Baja uses for they're tails. I'm interested in these, but the pricing seems like it just keeps climbing. I'm on the fence between the Dana setup and the CMI's, but would like pricing.
[email protected]
Thanks.
Irishtornado is offline
Old 10-06-2007 | 11:21 AM
Unfortunately the prices of headers are not going down so if your looking to get some I would suggest you jump on now before the next price increase. CMI is a good looking header that has proven itself again and again and it would be a smart choice
Old 10-24-2007 | 10:44 PM
COuld you PM me a price for two sets for 496's with bravos.
Thx
PARADOX is offline
Old 10-25-2007 | 10:55 AM
having a problem with my PM
give me a call and ask for Adrian
661-295-7000
Thx
Old 10-26-2007 | 02:53 PM
661-295-7000
Adrien
Thanks for the info.
I will read up on the pin/nut replacement a little and I'l get back to you for the rings/gimbles and headers.
Thx
P
PARADOX is offline
Old 01-28-2008 | 10:17 AM
Get up to 20% off on all Headers.
Custom Marine is committed to producing the best marine exhaust systems in the world.
* The patented cool-collar accumulator, which eliminates header hot spots, cracking and the potential for water ingestion.
* The flex-flare header-to-tailpipe attachment, which makes header/tailpipe connections easier and more forgiving to production hull variances
* The Big Tube/Step Tube, the ultimate race header on the circuit today
* Stainless-steel blower intake manifolds and custom-built 180-degree headers to maximize big blocks' torque potential.
