bad valve springs
Poor performance. Backfire at high RPMs.
I bought a set of heads off EBAY
that said ready to run. I did not have time to go through them. I had no valve train noise. Took the boat back out of the water removed one valve spring and it tested WEAK
so I don't need to tell you the rest of the story
The boat has lost 700 rpms since built. Only runs 4500 rpms and set up has not changed.I bought it this way. Sounds like a simple fix to me. Sometimes at wide open throttle the boat seems to slow down and i havent pulled back on the throttle. Sounds like the answere. Twin motor set up and both motors have lost the same rpm. Engines were put together years ago, not alot of hours but years of sitting up.Valve springs coming up..
think horses... not zebras.... there about 50 other things MUCH easier and simpler to check that are FAR more likely to be the cause of your issue....
change them if you want... but ive got 20 bucks that , in the absence of any other symptom, says its something else.
