2500 duramax how much weight can i pull >
Old 08-04-2006 | 05:41 PM
Default 2500 duramax how much weight can i pull
how much weight can i pull with 2500 duramax ho with allison trans, 2006-2007
it's say max trailer weight 12,000 l.b. on toung 15,000 for a 5 weeler .
i will be towing on the toung .has anybody towed more then the 12k ? how does it handle ?
thank's for all your input
mike
mikebrls is offline
Old 08-04-2006 | 05:52 PM
RHC's Avatar
RHC
Default Re: 2500 duramax how much weight can i pull
Mike,,, Its always the same answer,,,,,
How far??
How fast??
How often??
You can pull 20 to 24thousand with that truck ,, but ,, ya cant stop it!!!
It really just depends! I know thats not the info your looking for ,,,, but -----
RHC
RHC is offline
Old 08-04-2006 | 07:02 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
If you exceed the tow ratings of the truck you will not have insurance coverage in the event of an accident/incident; no matter who or what is at fault. Your insurance company will cancel your policy.
Sydwayz is offline
Old 08-05-2006 | 04:27 AM
thank's
mikebrls is offline
Old 08-07-2006 | 05:51 AM
hp500efi's Avatar
Member #9
make sure you upgrade the trailer hitch to a class5
Member of the Liquid Jungle
hp500efi is offline
Old 08-07-2006 | 06:36 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
True and great point. Even if you plan to tow within the factory specs, the factory tow hitch is junk. Go for a Reese Titan-V or a Putnam XDR Class-V hitch.
Sydwayz is offline
Old 08-07-2006 | 07:44 AM
Tim G.'s Avatar
Performance Boat Center
Like Brian says.. Change the hitch for safe measure.
I haven't changed it, and have pulled a LOT more than you'd believe (22,000lb)
You'll likely be fine stock, but a bigger hitch is no bad idea.
It's a damn good truck. I have an awful lot of seat time in the GM, towing seat time.
Tim Gallagher
Performance Boat Center-FL
[email protected]
954-809-8739
Wright Performance, MTI, Cigarette, Sunsation
Tim G. is offline
Old 08-07-2006 | 08:04 AM
Registered User
Amen.
Overweight towing is Russian Roulette with 5 bullets. Anyone who tells you different is a fool.
Chris Sunkin is offline
Old 08-07-2006 | 12:28 PM
Wobble's Avatar
SORE MEMBER
Ive pulled 12k on the hitch with my 06 2500hd. Absolutely no problem, however if I was going to pull weight in that range on a regular basis, I'd go with a dually for the peace of mind.
Wobble is offline
Old 08-08-2006 | 06:52 AM
OldSchool's Avatar
Don't forget the rear airbags!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OldSchool is offline
