Has anyone put Konrads on a 36 spectre?? >
Old 08-05-2006 | 09:26 PM
Default Has anyone put Konrads on a 36 spectre??
Or other larger cats .....If so how have they performed and held up. I have approx. 800hp and continue to have drive problems with XR's with Max Machine upgrades. Thanks for any input
bonecrusher is offline
Old 08-06-2006 | 03:50 AM
berns29scarab's Avatar
Default Re: Has anyone put Konrads on a 36 spectre??
nope, call me 1-732-684-4918
berns29scarab is offline
Old 08-06-2006 | 05:44 AM
Biggus's Avatar
Yes, about a year ago, Ohio Performance converted a 2005 36 Spectre from Bravo's to Konrad 540's. Boat works great. Zero drive problems since refit.
Last spring, DME in Windham, Maine converted a 34 DCB fro Teague Platinum drives to the Konrad Ace system. Also works great, no problems.
Kurt
[email protected]
Biggus is offline
Old 08-06-2006 | 06:11 AM
Strip Poker 388's Avatar
Rob
Kurt
[email protected]
What power did thay have ?
Strip Poker 388 is offline
Old 08-06-2006 | 06:54 AM
Biggus's Avatar
The Spectre has a pair of 950's The DCB has Teague 800's
Biggus is offline
Old 08-06-2006 | 07:03 AM
Rob
I heard the Spectre's were tuff on prop shafts???I bet the DCB was flying
Old 08-06-2006 | 11:59 AM
I have broken a couple prop shafts myself. Wern't you installing the new BMAX HT drives on your boat, have you put them on yet? if so how are they?
Old 08-06-2006 | 02:06 PM
Lofty's Avatar
Jerry, youres will be the first Spectre.
Did you get your drive back for the Big Cat? If not you can ride with me, I've got room for one more. You won't have to worry about me breaking a drive either
We're over 150 hrs and still no problems with the Konrads. Oil comes out clean every time!
Attached Thumbnails Has anyone put Konrads on a 36 spectre??-tn_img_0116.jpg
Lofty is offline
Old 08-06-2006 | 07:10 PM
I think I will be up and running, Drew should have it done early this week. Thanks for invite. I will start conversion as soon as summer is over. Are you going Friday night? Any idea how many boats are going this weekend? See either Fri or Sat.
Thanks Jerry
Old 08-06-2006 | 07:38 PM
Lofty's Avatar
Jerry,
Talked to Tony yesterday, says he's expecting over 250 boats and has spots for 160. Should be interesting. I think alot of guys are comming up from LA and apparently 20 or so from back east.
I'm staying at Jonas's from Fri thru' Sunday. I know it's a short drive but you know how the after party's go
Drew's a good man! Boat Masters is one of the best shops around. If he says it'll be done he'll get it done.
Fionn
Lofty is offline
