worst boating day this year >
Old 08-08-2006 | 07:04 PM
ToTheMax's Avatar
Default worst boating day this year
A beautiful, georgious day on Georgian Bay...Out at Beckwith Island, and the starter went! Got a tow-boat to come over and give us some extra juice to start it up, thankfully no 3hr tow home...
A couple of questions: how long do starters usually last for? Boat is a 22' Mariah with 280hrs. This may sound a bit dumb, but do any of you carry extra ones on board, or is there an easy alternative way to get the engine fired up?
any info greatly appreciated! (in the meantime I'll be drinking some cold ones at the dry dock )
ToTheMax is offline
Old 08-08-2006 | 07:42 PM
BRUCE SEROFF's Avatar
Default Re: worst boating day this year
point it downsteam and pop the clutch
BRUCE SEROFF is offline
Old 08-08-2006 | 07:49 PM
Tantrum's Avatar
If thats your worst day boating maybe more of us should look into buying a Mariah
Tantrum is offline
Old 08-08-2006 | 07:53 PM
Wobble's Avatar
SORE MEMBER
If extra juice got it going, it may be the relay mounted on the front of the motor that's gone bad, will make a clicking sound.
You can always jump from the battery positive on the starter up to the starter solenoid terminal and get most starters to function when you are in a bind.
Starter life varies with the amount of moisture and use. No predicting how long they will work. My mini reduction starter has been on for 5 years, however I am on my second remote starter relay.
Wobble is offline
Old 08-08-2006 | 07:58 PM
wrinkleface's Avatar
I heard that!
wrinkleface is offline
Old 08-08-2006 | 08:34 PM
johnnyboatman's Avatar
low voltage will cause starters to go out quicker alway make sure the battery is fully charged
johnnyboatman is offline
Old 08-08-2006 | 09:23 PM
cuda's Avatar
Check ALL your terminals and connections.
cuda is offline
Michael1
04-16-2008 09:57 PM
Jupiter Sunsation
11-26-2007 04:52 AM
docmanrich37
08-12-2007 06:53 PM
Edward R. Cozzi
04-04-2006 02:33 PM
klaw
11-27-2003 10:41 AM
