How often do you go WOT? >
Old 08-08-2006 | 09:22 PM
pkspx's Avatar
Default How often do you go WOT?
I'm curious to know how many of you go WOT on your stock/built engines. Currently mine is built mostly for pleasure boating. I'm getting closer to 200hours and nervous that the more i hit WOT im going to ruin the block. Last 454 cracked in cyl 7 not sure if it was stress or what. I do not ride WOT all the time but I will cruise at 4000-4700 and sometimes tap to full throttle but let off when oil temps build over 230F. PS I have been trying to take good care of it every 10hours oil changes and full warm ups until oil temps build over 180degree. Anyone else ride WOT? for more then 2mins?
EDIT: PS using 50W oil because of the clerences in the engine suggested from my builder.
pkspx is offline
Old 08-08-2006 | 09:57 PM
Default Re: How often do you go WOT?
All the time, besides dock / no wake time, I'd bet I am WO 80% or better of the time.
With how often you're changing oil, and the care you are taking, your oil can go past 230. 300 is the general breakdown limits of conventional oil, but personally i'd try not to go over 250.
jmherbert is offline
Old 08-08-2006 | 10:04 PM
99fever27's Avatar
I run WOT maybe 20% of the time usually due to running out of water and ignorant people on jet skiis.
99fever27 is offline
Old 08-08-2006 | 10:07 PM
Thats why I am only 80%
Old 08-08-2006 | 10:08 PM
Wobble's Avatar
SORE MEMBER
2-3 times each day out generally less than a minute at a time just for the feel and to blow it out.
Ran WOT during a poker run last year for about 20minutes trying to make up some lost time.
Not doing any PR's this year to save on gas
Wobble is offline
Old 08-08-2006 | 10:23 PM
Every now and then when someone rides up next to me....
Back4More is offline
Old 08-09-2006 | 12:19 AM
Probabaly 5-10% of the total hours. Running wot for 1-5mins at a time mostly.
Griff is offline
Old 08-09-2006 | 05:42 AM
Payton's Avatar
Charter Member #927
I am about the same.
Payton is offline
Old 08-09-2006 | 08:14 AM
Keep in mind my WOT is in the fifties
Old 08-09-2006 | 12:10 PM
mopower's Avatar
Toxic FORMULA
3000 rpms gets me in the 50s and thats a very comfortable cruise for my boat. Usually one short blast of WOT per trip.
mopower is offline
