Thundrebolt IV ignition module >
Old 08-09-2006 | 05:50 PM
seahawk's Avatar
Default Thundrebolt IV ignition module
Where do I get one? Do they still make them? Mine has stamped on it 8C31A V8 HP its for 509CI w/ 250 blower
seahawk is offline
Old 08-09-2006 | 08:34 PM
seahawk's Avatar
Default Re: Thundrebolt IV ignition module
ttt
seahawk is offline
Old 08-09-2006 | 08:43 PM
MrCIG's Avatar
Charter Member#330
That number doesn't show up on this document
MrCIG is offline
Old 08-09-2006 | 08:53 PM
mopower's Avatar
Toxic FORMULA
Heard that one(V8 HP) is no longer available
mopower is offline
Old 08-10-2006 | 03:23 AM
Yep, listed as no longer available. Its the module used on HP500's with a TB IV ignition.
Best options would be to find a used one or switch to a V6 module or get a Crane box and use one of there preset timing curves.
Griff is offline
Old 08-10-2006 | 07:14 AM
EYEBURN's Avatar
i have a v8-hp and a v8-20, anyone know what the difference is in the timing curve, i think they are both 20* advance but one comes in slower and i think the HP is all in by 3000rpm or something like that.
im running the v6 module for a blower application. only 14* advance.
kevin
EYEBURN is offline
Old 08-10-2006 | 08:16 AM
The HP modules are discontinued. I always ran the V6 module on my SC engines.
EYEBURN, you are correcty. The V8-20 only has about 15 degrees at 3000 rpm. Full advance is over 4000 rpm.
Gary
rdoactive is offline
Old 08-10-2006 | 12:41 PM
seahawk's Avatar
Dose any now the item number for the one that replaces it or a different one that will work the same.
seahawk is offline
Old 08-10-2006 | 01:08 PM
Dave_N's Avatar
I graphed the Tbolt IV advance curves based on the information given in Dennis Moores BBC book.
Dave
Dave_N is offline
Old 08-10-2006 | 01:21 PM
No replacement listed.
http://www.mercruiserparts.com/Show_...CAL+COMPONENTS
Griff is offline
