AFR the real deal Marine Heads
Why settle for less? Bob Teague spent some time at the ARF factory and helped develop a program for what we like to call a true HIGH PERFORMANCE CNC MARINE HEAD.
All the heads in stock are madewith 3/8 exhuast valves instead of 11/32 because we think that the thicker valve stem is much stronger especialy for the punishing heat and rpm most high performance motors make.
With this CNC program you get THICKER VALVE SEAT WIDTHS for more surface area to transfer heat.
A chamber of 124cc instead of 121cc, the bigger chamber drops static compression so you can run more boost and the custom chamber design also picks up exhuast flow to make more power on blower motors.
So as you can see by some of the things we do different on our CUSTOM CNC AFR HEADS from the AFR heads you can buy somewhere else you not only get a much stronger set of heads but a more POWERFULL set of HEADS.
These are the same heads that we use on every motor we build and they are available to you. Why settle for less ? There is no reason, just buy the best...........
I have them in stock
we get them in by the pallets and i always have them in stock
PART NUMBERS
#3350-TF-TCM TCM SPECIAL CNC 335CC BARE HEADS PR
#3570-TF-TCM TCM SPECIAL CNC 357CC BARE HEADS PR
YOU CAN ALSO GET THEM ASSEMBLED
PART NUMBERS
