99 F-250 powerstroke suspension
Old 08-10-2006 | 08:59 AM
berns29scarab's Avatar
Default 99 F-250 powerstroke suspension
I have a 99 F-250 xtra cab powerstroke 4x4 and just installed LT 305-55-20's. The front of the vehile sags a bit. Is there a way to just raise the front of her without doing an entire lift kit. I dont want to kill the ride of the truck. Was told to install a fabtec 5.5 lift kit but dont really want to lift her that much. Any ideas?
berns29scarab is offline
Old 08-10-2006 | 10:30 AM
comp's Avatar
Default Re: 99 F-250 powerstroke suspension
call Ralph at meadowlands 4 wheel drive in eath rutherford NJ.
he has been lfting trucks since the 70's
973 472 1120
comp is offline
Old 08-10-2006 | 10:33 AM
a leveling kit. check with fabtech or www.superdutyheadquarters.com www.donahoeracing.com
JPD Motorsports is offline
Old 08-10-2006 | 06:55 PM
eyezlee's Avatar
Get a hold of buck183. He cann tell you what you need, then you can pick it up locally.
The leveling kit is what I'm doing to my 2003 this winter.
Do you have any pics?
eyezlee is offline
Old 08-10-2006 | 07:35 PM
I did the jackit leveling kit on my 01 350. It looks great but rides like ****.
area51scarab is offline
Old 08-10-2006 | 07:46 PM
mopower's Avatar
Toxic FORMULA
Mine has the blocks removed over the rear axle. This lowered the rear so it sits level . Also has 20" wheels and 305/50-20 tires.
Attached Thumbnails 99 F-250 powerstroke suspension-3b35.jpg   99 F-250 powerstroke suspension-79db.jpg
mopower is offline
Old 08-11-2006 | 08:22 AM
i was told to find a spring shop and re arch the front spring and add a leaf or to get the drop down bracket for the front. drops the front spring mounts approx 2-2.5 inches...hmmmmm.
Old 08-11-2006 | 08:30 AM
couple pics
Attached Thumbnails 99 F-250 powerstroke suspension-dscn7949.jpg   99 F-250 powerstroke suspension-dscn7950.jpg   99 F-250 powerstroke suspension-dscn7948.jpg
Old 08-11-2006 | 08:32 AM
i have the same size tires but about 2 3rds turned to eaither side and i rub the back of the front fender wheel lips
Old 08-11-2006 | 10:36 AM
mopower's Avatar
Toxic FORMULA
You posted 305/55-20 , mine are 305/50-20. That would make your diameter just slightly larger...and mine JUST clear
mopower is offline
