engine change >
engine change
engine change
Old 08-15-2006 | 08:57 PM
Default engine change
i am new hereso I would like to start by saying Hi to every one, I have a Gm 350 that I just bought ran great but the block is cracked so what i want to do is replace it with the crate motor I bought for my truck do I have to change anything besides the carb, distribitor,starter,and altinater can I leave the rest as is , as in the heads manifolds cams and crank
Are if theres somthing you think I should swop out from the other motor let me know thanks
virago is offline
Old 08-15-2006 | 09:39 PM
GOODT's Avatar
Default Re: engine change
freeze plugs and head gaskets......... freeze plugs need to be brass and head gaskets need to be stainless
GOODT is offline
Old 08-16-2006 | 05:33 AM
So The heads and cam thats on engine now are fine right ? great thanks for the help
virago is offline
Old 08-16-2006 | 05:50 AM
Payton's Avatar
Charter Member #927
You mentioned manifolds. Intake manifold can stay but you have to use the marine exhaust manifold.
I would say the cam is a big maybe. Can you post the cam specs? It may be fine, or you may simply not have optimum performance, or it may ingest water into the engine . That is called reversion.
Payton is offline
Old 08-16-2006 | 06:28 AM
SB
Ton of different crate motors available from GM - please tell us which you have.
SB is offline
Old 08-16-2006 | 07:45 PM
Ok this is the info I found not sure if its right so here goes on the crate motor
Casting # 10066036
350 Cubic inches 4.00" Bore, 3.47" stroke
8.0:1 compression ratio.
250 HP @4300 rpm 350 ft. lbs of torque @ 3600 rpm
Engine consists of the following parts:
Block -part # 10066034, casting # 10066036 2 piece rear main seal 4 bolt main
Crankshaft- part # 3932444 Nodular Iron 1985 and older flywheel bolt pattern.
Connecting rods- Part # 10108688 Powdered Metal
Pistons- part#12514101 Cast Aluminum
Oil Pump- part # 12555284 G.M. High Volume Pump
Camshaft- Part#3863151 Hydralic Flat tappet
Intake Lift-.383" Exhaust Lift-.401"
Intake Duration @ .050"- 194° Exhaust Duration @.050"- 202°
Lobe Seperation-112°
This cam Has a mechanical Fuel Pump Lobe. This is a low end Torque oriented camshaft.
Cylinder Heads- part # 14034808 casting #33417369
1.94" Intake valve , 1.50" Exhaust Valve 76cc Combustion Chamber
7 Bolt style Exhaust Flange Standard 85' and prior intake manifold bolt pattern.
Perimeter bolt style Valve Covers. This head is very similar to the old #882 castings from the 1970's
Ok this is what I have found by lookung up the casting #'s if you guys can find any thing let me know
I believe the cam in the old marine motor is like 450-460 where the one in the crate is 383-401 I beleive Ill leave that cam in what do you guys think?
I will how ever be swaping heads from the 1.94" Intake valve , 1.50" Exhaust Valve 76cc Combustion Chamber
to the 14096217 350 87-up 350/285hp crate engine, 64cc, 1.94"/1.5" valves, 72° intake bolt angle again what do you guys think
Pleas I would like all your input
virago is offline
Old 08-17-2006 | 09:35 AM
hunster's Avatar
cam!
hunster is offline
Old 08-17-2006 | 07:36 PM
Originally Posted by hunster
cam!
As in leave the Intake Lift-.383" Exhaust Lift-.401" cam thats in the crate motor in there are put the 450-460 cam in
virago is offline
Old 08-18-2006 | 05:09 PM
Where did every one go lol
virago is offline
Old 08-18-2006 | 05:52 PM
Payton's Avatar
Charter Member #927
There are better cam experts out there. I don't think that cam will hurt anything, it just run as good as it could.Kind of low performance.
Payton is offline
