Ken Warby.. the real speed king >
Old 08-17-2006 | 09:05 PM
Default Ken Warby.. the real speed king
Ken
when do you think you will attempt a run for the record...
they are a few on here that need schooled..
http://www.kenwarby.com/introduction.htm interesting read
customryder is offline
Old 08-17-2006 | 09:17 PM
Pantera1's Avatar
Default Re: Ken Warby.. the real speed king
317 end of story
Pantera1 is offline
Old 08-17-2006 | 09:44 PM
Ron P's Avatar
Enjoy the show
He is Da Man. No need to risk his life again.
From EBM Two years ago.
Setting the World Water Speed Record has been Ken’s life passion. His mind was made up from the time he was eight years old and glued a CO2 cartridge to a model boat and blew it across a neighbor’s pool. Thirty years later he claimed ownership of the record and lived to tell the story.
EBM – Ken, I guess I should introduce you as the most extreme boater of all time. What is your record, 317?
KW – 317.6 to be exact. And we set that record 27 years ago.
EBM – I’m sure that type of effort cost a small fortune. Where were you living and what were you doing to make money back then?
KW - I was living in Australia and doing oil paintings in shopping centers.
EBM – You made enough money painting murals to take on a World Speed Record project?
KW – How much do you think the first boat cost to build and run?
EBM – I can only guess, three or four hundred thousand dollars?
KW – Not even close.
EBM – More than that?
KW – Far less, we built that boat under a tree in the backyard of a rented house. We had a tarp to throw over it at night, that was about it. It was made of plywood and then wrapped in fiberglass. We bought three jet engines at a government auction. I got two J34 engines for $200 and a third for $65. We put together the entire boat for less than $10,000.
EBM – So you set the record of 317.6 using a $100 jet engine?
KW – Not exactly. We set the Australian Speed Record of 288 using one of those engines but it was flat out. A year later, after the Air Force mechanic’s academy rebuilt the $65 engine for me, we set the World Record at 317.6 and she had more to go.
EBM – I understand you have a new boat built and your looking to better your existing record.
KW – Yes it’s over in Australia, the problem is the water level is too low at the dam that we use for the record attempts and there’s just no room to run.
EBM – I bet the new boat cost more than $10,000 to build.
KW – Hell, I paid that much for the rudder on the new boat.
EBM – Have you tested the new boat?
KW – Yes we have a river that we run on but speeds are held to around 200mph because it’s a narrow river and there’s no room for error.
EBM – Are you ready to go faster?
KW – Yes we just made some changes to the shape of the sponsons and we are ready to go faster.
EBM – What are you using for power this time.
KW – Same motor as last time, a Westinghouse J34 that makes about 3500lbs of thrust.
EBM – Any safety equipment this time?
KW – Last time I didn’t even have a seat belt. The new boat has a F16 canopy, safety cell, 5-point harness, onboard air, fire extinguishers, and a radio so I can talk to my team, we really went all out on the new boat.
EBM – Now for the $64,000 question: You’ve held the record for 27 years, two guys have died trying to better your speed, there’s some talk of a challenger but no boat has been built as of yet. So why would you risk your life again to better your own record?
KW – I get a real kick out of the designing and building of the craft, you could put a trained monkey in to drive it. We have until October of this year to set the record or we have to get the boat out of Australia. If we don’t have time I’ll bring it back to my home in Cincinnati. Maybe I’ll put it on a pole in front of my house as a monument to stupidity. I’m going to be 66 years old next month and I have a deal worked out with Howard Arneson, I’m not going to retire until he does, and he’s in his mid 80s. In fact he and I have spent a lot of time talking about building a boat using his surface drive to set the propeller driven speed record.
Ron P is offline
Ron P's Avatar
Enjoy the show
Since the time Ken set the record back in October of 1978 two other challengers have tried to better his mark, both ending in tragic failure.
In 1980, the previous water speed record holder, Lee Taylor, tried to reclaim his title in a 2.5 million dollar boat called "Discovery II." The missile-shaped craft was constructed of aluminum, titanium and stainless steel and was powered by a rocket engine that burned hydrogen peroxide fuel. The power plant was said to generate 8,000 pounds of thrust.
The trial took place November 13, 1980 on Nevada's Lake Tahoe. Discovery II roared through its first pass at 269.85 mph and was decelerating when it appeared to hit a swell. Witnesses reported that the boat veered to the left and suddenly disintegrated, vanishing under the surface of the lake in a matter of a few seconds. Taylor’s body was found a day later still strapped into the cockpit.
Craig Arfons, a former automotive drag racing champion and a close friend of Ken Warby was the next to take up the challenge. In July 9, 1989, he put the finishing touches on a jet hydroplane called "Rain-X Record Challenger," which boasted a lightweight composite hull and a jet engine that could deliver 5,500 pounds of thrust with the afterburner lit. Arfons calculated that the boat's favorable thrust-to-weight ratio would give it a 200 percent power advantage over Warby's record-setting boat.
The record attempt took place on Jackson Lake near Sebring, Florida. Members of Arfons' crew say his boat reached a speed of 263 mph before it became airborne and began to cartwheel across the mirror-smooth lake. Arfons tried to deploy a safety parachute, but the angle at which his boat was traveling prevented the parachute from opening. Arfons was killed as his boat shattered around him. He was 39.
Ron P is offline
Old 08-17-2006 | 09:45 PM
Ron P's Avatar
Enjoy the show
Holders of the UIM World Water Speed Record
92.84 mph George Wood (USA) Miss America 7
04 December 1928 Revier Canal, Detroit, Michigan, USA
93.12 mph Gar Wood (USA) Miss America 7
25 March 1929 Indian Creek, Miami, Florida, USA
98.76 mph Sir Henry Segrave (GB) Miss England 2
13 June 1930 Lake Windermere, England
102.25 mph Gar Wood (USA) Miss America 9
20 March 1931 Indian River, Florida, USA
103.49 mph Kaye Don (GB) Miss England 2
02 April 1931 Parana River, Argentina
110.22 mph Kaye Don (GB) Miss England 2
09 July 1931 Lake Garda, Italy
111.72 mph Gar Wood (USA) Miss America 9
08 February 1932 Indian River, Florida, USA
117.43 mph Kaye Don (GB) Miss England 3
16 July 1932 Loch Lomond, Scotland
119.81 mph Kaye Don (GB) Miss England 3
124.86 mph Gar Wood (USA) Miss America 10
20 September 1932 St. Clair River, Detroit, Michigan, USA
126.33 mph Sir Malcolm Campbell (GB) Bluebird K3
01 September 1937 Lake Maggiore, Italy
129.56 mph Sir Malcolm Campbell (GB) Bluebird K3
02 September 1937 Lake Maggiore, Italy
130.93 mph Sir Malcolm Campbell (GB) Bluebird K3
17 September 1938 Lake Hallwyl, Switzerland
141.74 mph Sir Malcolm Campbell (GB) Bluebird K4
19 August 1939 Coniston Water, England
160.32 mph Stanley Sayres (USA) Slo-Mo-Shun 4
26 June 1950 Lake Washington, Washington, USA
178.49 mph Stanley Sayres (USA) Slo-Mo-Shun 4
07 July 1952 Lake Washington, Washington, USA
202.32 mph Donald Campbell (GB) Bluebird K7
23 July 1955 Lake Ullswater, England
216.23 mph Donald Campbell (GB) Bluebird K7
16 November 1955 Lake Mead, Nevada, USA
225.63 mph Donald Campbell (GB) Bluebird K7
20 September 1956 Coniston Water, England
239.07 mph Donald Campbell (GB) Bluebird K7
07 November 1957 Coniston Water, England
248.62 mph Donald Campbell (GB) Bluebird K7
10 November 1958 Coniston Water, England
260.35 mph Donald Campbell (GB) Bluebird K7
14 May 1959 Coniston Water, England
276.33 mph Donald Campbell (GB) Bluebird K7
31 December 1964 Lake Dumbleyung, W. Australia
285.21 mph Lee Taylor (USA) Hustler
30 June 1967 Lake Guntersville, Alabama, USA
288.18 mph Ken Warby (Australia) Spirit of Australia
20 November 1977 Blowering Dam Reservoir, NSW, Australia
317.60 mph Ken Warby (Australia) Spirit of Australia
08 October 1978 Blowering Dam Reservoir, NSW, Australia
Ron P is offline
Ron P's Avatar
Enjoy the show
You have to question the sanity of people that chase World Speed Records. No doubt it’s a dangerous venture, from the statistics, probably the most dangerous passion of all. Since Ken set the record, he’s watched two of his friends, Craig Arfons and Lee Taylor, die trying to take the record away from him. Nowadays there are three efforts to break Ken’s record. One group in Seattle Washington known as the American Challengers www.americanchallengewsr.com, Britain’s bid at the World Water Speed Record known as Quicksilver www.quicksilver-wsr.com and the other is Ken Warby www.kenwarby.com himself. Ken’s new boat has been tested to 200mph on a river in Australia and is ready to move onto the next phase of testing. Whereas the American Challenger is still residing on a hard drive in a Seattle based computer and the Brits won’t get wet for years. Ken is truly a man on a mission.
Ron P is offline
Old 08-18-2006 | 12:22 AM
Semper Fi's Avatar
It's incredible what Ken Wharby attained in a home-made boat built in his backyard. Even with all the technology today, nobody has beat him...that's impressive.
It takes a man with HUGE BALLS, like Ken Warby to do this, knowing the ultimate consequences
Semper Fi is offline
Old 08-18-2006 | 01:37 AM
packinair's Avatar
No Comment
From: This post copyright, Packinair Inc. All rights reserved.
he and his boats can be found in the AMF pits at almost every race. He has been and continues to be a huge part of AMF. if you ever get the chance to sit down and talk to him he is a hell of a nice guy...
"how bad do you want it" Ken Warby
packinair is offline
Old 08-18-2006 | 07:14 AM
Pantera1's Avatar
Yes , nice guy as well
Pantera1 is offline
Old 08-18-2006 | 07:19 AM
Ken has been a tremendous help to my team.
A one of a kind!
Dan
dan lawrence is offline
