Cleaner for salt water spots on glass. >
Old 08-19-2006 | 10:50 AM
Smile Cleaner for salt water spots on glass.
I try to make sure I rinse or wash the boat after use in saltwater, but still can't seem to get the water spots all off. I know there was a thread soemwhere I think on this issue but can't seem to find it.
Any help on some good cleaners would be appreciated!
Thanks,
Shawn
29scarab is offline
Old 08-19-2006 | 11:43 AM
BY U BOY's Avatar
Default Re: Cleaner for salt water spots on glass.
ARE YOU THINKING ABOUT SALT AWAY?
I HAVE HAD GOOD LUCK WITH GEL GLOSS. YOU CAN PICK IT UP AT HOME DEPOT OR TAGET.
http://www.waveplumbing.com/store/in...products_id=28
DID YOU FIND AN ALERNATOR FOR THAT 502
BY U BOY is offline
Old 08-19-2006 | 12:12 PM
It was the starter and a new IAC motor. Bought a new hi torque starter and it works great. Working on getting the IAC installed today and hopefully get a hold of the guy locally who has access to the mercruiser scanner I need. I want to check the IAC and also the TPS to make sure everything is working properly.
See if I can get that blasted engine from stalling when I put it in gear.
29scarab is offline
Old 08-19-2006 | 12:20 PM
BY U BOY's Avatar
HEY AT LEAST YOU CAN START YOU ENGINE ALL I CAN DO IS SIT BEHIND THE WHEEL AND MAKE VROOM VROOM NOISES.
GOOD LUCK
BY U BOY is offline
Old 08-19-2006 | 12:38 PM
GOOD LUCK
Now thats funny right there, I don't care what they say!!!
29scarab is offline
Old 08-19-2006 | 02:36 PM
Elite Marine's Avatar
Use vinegar to clean the spots. It removes the wax from your gel so you'll need to rewax those areas.
Elite Marine is offline
Old 08-20-2006 | 08:02 AM
Reckless32's Avatar
Rough Seas Lie Ahead
WD-40. Also good for shower stall glass.
Reckless32 is offline
CAP071
03-21-2008 10:50 PM
bidpro
08-09-2007 03:17 PM
k24u
3
06-12-2006 03:59 PM
CAP071
03-27-2006 12:20 PM
jeff32
01-09-2006 07:21 AM
