HOW TO MEASURE X DIMENSION >
Old 02-05-2002 | 08:37 PM
ateyet
Post HOW TO MEASURE X DIMENSION
IM IN THE PROCESS OF CHANGING FACTORY MERC. EXHAUST AND NEED TO FIND THE X DIMENSION. THE BOAT HAS A 502 EFI WITH STOCK MANIFOLDS AND A 3 INCH SPACER BETWEEN THE RISER. THEN THRU HULL
Old 02-05-2002 | 08:41 PM
Tinkerer's Avatar
Cool
If your buying new header exhaust all you should have to tell the manufacturer is that you have a BBC bravo package with a 3 inch riser.
Tinkerer is offline
stormbauer
Drives and Lower Units
10
10-27-2008 01:49 PM
mirageman
01-08-2004 09:49 AM
Intolerant1
14
07-24-2002 09:34 PM
