Any Chevy dealers out there?
I am looking at an older Suburban in another state and am trying to find out what equipment it might have on it.
Can anyone run a vin number and tell me what it might have been ordered with? Thanks
1GNGK26J6XJ328975 1999 3/4 4x4
There should be a build sticker in the glove box.
GT4 - 3.73 Rear Axle Gear Ratio
GT5 - 4.10 Rear Axle Gear Ratio
G76 - POSITRACTION REAR
G80 - AXLE POSITRACTION, LIMITED SLIP
G81 - POSITRACTION REAR AXLE
This page is dated, but many of the codes are still used much the same:
http://www.chuckschevytruckpages.com...s_1973-87.html
This page has ALL RPO Codes used by GM:
http://www.c2e.biz/rpocodes/MODERNGMRPO.html
Well I know it's white can't tell interior, base package 1SA, Locking diff, front and rear air, problem is gm does not define codes that old. Here is a list of codes on the vehicle...
AS3 AT5
AU3 AU6
AXP A52
B85 C25
C36 C49
C6P C60
C69 DE2
E55 FE9
FF8 FF9
F60 GAM
GT4 G80
JAN JD7
KNP KW2
K34 L29
MT1 NF2
NY1 NZZ
N33 QIW
R9V SLL
TEJ UM7
UQ5 VGC
VK3 VXS
V73 V95
XGK X88
YD3 YD6
YGK ZGK
ZK3 ZP6
ZQ3 ZY1
1SA 1SZ
13I 13V
5V6 50U
6GL 7GL
Hope this helps...
Rob
AS3 AT5
AU3 AU6
AXP A52
B85 C25
C36 C49
C6P C60
C69 DE2
E55 FE9
FF8 FF9
F60 GAM
GT4 G80
JAN JD7
KNP KW2
K34 L29
MT1 NF2
NY1 NZZ
N33 QIW
R9V SLL
TEJ UM7
UQ5 VGC
VK3 VXS
V73 V95
XGK X88
YD3 YD6
YGK ZGK
ZK3 ZP6
ZQ3 ZY1
1SA 1SZ
13I 13V
5V6 50U
6GL 7GL
Hope this helps...
Rob
I see GT4 there. That is definately a 3.73 rear end. That code has been around forever. HOWEVER, it could always have been swapped out by an owner.
GM used to have 3 option packages in most cases.
1SA is pretty basic.
1SB was modern conveniences; AC, PDL, PW, usually the LS model.
1SC was the full monty, usually the LT model with leather, and the nicer stereo.
If its a 1999 with the 7.4L, then it has the Vortec heads and intake which makes for a pretty solid motor. You would not want 1 1995 or earlier. 1997 added a second airbarg, so there is one for the passenger and the driver.
Aggressor 25 here on OSO had the same truck, lifted, and on 35s. He ran it for well over 100,000 miles with no major issues before he sold it.
Boomer35
4
11-21-2007 11:34 PM
Pantera1
14
04-16-2006 09:07 PM
