water in valve covers..but not on dipstick >
Old 08-20-2006 | 07:51 PM
Default water in valve covers..but not on dipstick
I got a vanilla milkshake in my valve covers but not on my dipstick. What would cause this. It is way to much for condensation, When I pull the vents off the covers while running it will actually spit water out!
jdub is offline
Old 08-20-2006 | 07:54 PM
Lofty's Avatar
Default Re: water in valve covers..but not on dipstick
Could be early signs of reversion. How old is you exhaust and what is it?
Lofty is offline
JCPERF's Avatar
Not enough oil temp or and excessive blow-by.
JCPERF is offline
Old 08-20-2006 | 08:08 PM
stainless marine, got a couple seasons on them. I just put the two inch spacers on them to get over my rubrail and noticed some water leaking out of the flange where the manifold and riser are clamped together. But there shouldn't be water in there unless: reversion, cracked manifold or cracked riser right?
jdub is offline
Old 08-20-2006 | 08:11 PM
JC I did a compression test and 2 4 6 8 and 7 were all around 140 but 1 3 5 were around 115. Would this show blow by.
jdub is offline
Old 08-20-2006 | 08:21 PM
JCPERF's Avatar
Being that 3 cylinders are down from the rest could be a sign of those cylinders not sealing and causing blow-by.
JCPERF is offline
Old 08-21-2006 | 01:43 AM
vandeano's Avatar
If you been running it like this for awhile. Take the engine out and tear it apart and check your bearings. I ran mine like that for a very short time and wiped out all my bearings. Bearings don't take to kindly to condensation even for a short time.
vandeano is offline
BLOWN85
2
03-02-2008 08:46 AM
cloudmaster_321
4
06-01-2005 07:07 AM
wallynt
8
04-22-2005 02:16 PM
challenger454
4
05-26-2004 12:10 PM
treatj24
4
01-21-2003 02:02 AM
