Holding tank solutions...
Old 08-21-2006 | 04:27 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Holding tank solutions...
I am looking for a different solution, and the holding tank in my boat is really small. I am going to pull out the whole system (my macerator has an electrical issue) I am thinking of going to this bladder (no peanut gallery comments please) system.
Docmanrich37 installed one in his 37, but he is the only person I know with this product, and I was just looking for more input. His is working great, and he is happy with it, but before I invest the time, money, and not so pleasant effort, I would like to hear more experiences if they are out there.
http://www.imtra.com/product/pumps_t...s/ft915152.htm
http://www.imtra.com/downloadTypes/N...ible_Tanks.pdf
Thanks in advance.
Sydwayz is offline
Old 08-21-2006 | 09:08 AM
Offshoreonly Advertiser
Default Re: Holding tank solutions...
Bajabob 38 And A Straw !
sy goldberg is offline
Old 08-21-2006 | 09:15 AM
Snail-boats have been using bladder-tanks forever. Just make sure it's well anchored into it's space.
hpoffshore is offline
Old 08-21-2006 | 09:19 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thanks Hugh (and Sy).
Anyone else?
Sydwayz is offline
Ted G's Avatar
I had one in my big boat for a while. I would not recommend it. First they let more stink through than a hard tank. I also had a problem with clogging the vent line. At times when the tank is empty the vent line (on top) will collapse against the bottom. If there is TP on the bottom it gets into the vent line and then dries-you are then screwed. Try and stick with a hard tank if you can. I went overboard when I redid the big boat and used almost all Sched 40 PVC pipe with angles and small pieces of hose on the ends to mate the head and tank. Absolutely no holding tank smell at all in the boat.
www.cbpba.com
Ted G is offline
Old 08-21-2006 | 10:25 AM
Actually, it's not usually the tank that gets the stink-on(although after a decade or so, it's certainly possible); it's more often than not, incorrect type or low-quality sanitation hoses that provide the ambiance, regardless of the boat's method of propulsion.
Old 08-21-2006 | 10:39 AM
Audiofn's Avatar
Charter Member #232
Toss it over with the bilge pump!!! I hated having the crapper on my boat. People would use it then I would have to clean it. NOTHING in this world is worse!!! So I just removed it. Amazing that if it is not on the boat people will make due with out it and plan around them.....
Put your best foot forward!
Audiofn is offline
Old 08-21-2006 | 10:45 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I am not going to get rid of it, it works well. The boat came with only a 6 gallon tank which really isn't much. I don't mind dealing with cleaning it; and its only me or my guest that use it. I have to pull out the actual head to TS the electrical issue. I know the one way valve that keeps anything from flowing back into the toilet bowl needs replaced, and I have a new one. While I am in there, I want to go ahead and get the bladder system to upgrade the capacity, and hopefully deal with less odors.
Sydwayz is offline
duksrule
1
07-26-2006 07:36 PM
duksrule
5
07-24-2006 01:41 PM
Sight and Sound
4
07-05-2006 05:28 PM
Scott
Powerquest
8
07-19-2004 08:14 PM
splashandburn
Sonic
7
07-15-2004 03:11 PM
