Surge to E/H Brakes
Old 08-22-2006 | 03:21 PM
aquatictherapy's Avatar
Default Surge to E/H Brakes
I am currently running surge brakes on my trailer. I am interested in switching to electric over hydraulic. If I do switch, do I cut the old coupler off and weld a new one on?
Scott
aquatictherapy is offline
Old 08-22-2006 | 03:31 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Default Re: Surge to E/H Brakes
Or just weld your existing one solid.
US1 Fountain is offline
Old 08-23-2006 | 01:35 PM
PIGPEN160's Avatar
Aqua,
Just Did The Same Conversion On An Aluminum Triple Axel Hauling A 38 Scarab. I Am Extremely Happy And Left The Coupler The Way It Was. It Moves But No Problem Leaving It That Way.
PIGPEN160 is offline
Old 08-23-2006 | 02:12 PM
44MTI's Avatar
I have done this a couple of times and can tell you that you will be very happy with the change and that it is a nobrainer.
First, just disconnect the brake line from the surge unit and connect it to a E/H actuator that has been bleed.
Then weld the coupler solid, This will take the slack out of the system and stop those jerks when you stop and start. It's really easy and a much better system.
44MTI is offline
Old 08-23-2006 | 02:32 PM
nordic95's Avatar
Where would one find the parts to make this conversion??
Thanks Nordic95
nordic95 is offline
Old 08-23-2006 | 02:48 PM
http://www.etrailerpart.com/
www.easternmarine.com
These are two that I have found that have the parts. I am sure there are many more. Scott
Old 08-23-2006 | 02:50 PM
44MTI's Avatar
Mine was a carlilie unit. Should be able to find a dealer new you on the web.
44MTI is offline
DMAX
6
10-14-2008 06:49 PM
augie58
6
04-07-2008 10:01 AM
mnmstoy
0
05-18-2007 01:25 PM
WETTE VETTE
7
08-29-2005 08:36 AM
KN
02-15-2002 09:58 AM
