Julie/Throttle-UP... Do you keep notes by Serial Number? >
Old 08-23-2006 | 12:09 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Default Julie/Throttle-UP... Do you keep notes by Serial Number?
I am looking at a pair of props that were reconditioned and labbed by Thottle-Up. The slip says just that; "Reconditioned and Labbed".
If I get the Serial Numbers for you, can you provide any insight?
I am running Stock 28P B1 props now, and these are Labbed 28P B1 props.
THANKS in advance.
Brian Tillett of the
OSO Winter Chill-Out(s); Richmond, VA
Sydwayz is offline
Old 08-24-2006 | 09:20 AM
throttleup's Avatar
Default Re: Julie/Throttle-UP... Do you keep notes by Serial Number?
Let me know what you come up with Brian.
Julie
throttleup is offline
Old 08-24-2006 | 06:41 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thanks for the chat Julie. I bought the props. I can't wait to try them
Sydwayz is offline
Old 08-25-2006 | 07:58 AM
throttleup's Avatar
Give me a call after you run them and we can take a look at your numbers.
Safe Boating!
Julie
Old 08-30-2006 | 12:52 PM
EYEBURN's Avatar
Julie,
I was wondering the same thing, am looking at a 26 bravo that you have "blueprinted" is there a serial # or something that i can get from the prop to find out from you what was done to the prop?
kevin
EYEBURN is offline
Old 08-30-2006 | 03:29 PM
throttleup's Avatar
If you can give me the name of the original buyer, I can certainly pull some info up for you. No problem!
Julie
Carder
Prop Talk
1
06-04-2007 08:49 PM
pol98xc6
Prop Talk
8
05-31-2007 07:58 AM
duunoit
0
04-01-2007 07:54 PM
TxFountain
Prop Talk
0
09-03-2006 06:38 PM
Dregsz
0
06-08-2005 11:30 PM
