Go Back  Offshoreonly.com > Owners Forum > Powerplay
Hot Property >
Hot Property
Hot Property
Old 08-24-2006 | 02:06 PM
Default Hot Property
Well Hot Property is for sale again. She will be out of the shop sporting two totally redone 500efi's with a one year warrenty. If you forgot she is a 2001 33 powerplay with bravo XR drives. About 240-260 hours on her and zero on the rebuilds. Let me know if you are interested or any questions. The picture will be up as soon as she comes back. And then its totally official.
trader1 is offline
Old 08-24-2006 | 03:27 PM
Indy's Avatar
Member #154
Default Re: Hot Property
Wow...too bad, is this a good thing or a bad thing?
Indy is offline
Old 08-24-2006 | 04:31 PM
Mixed emotions at this point. I am going to sit out a year and decide what I want with no payments or expences. Atleast I know she is right and ready to run.
trader1 is offline
Old 08-25-2006 | 08:57 PM
XPRESS 33PP's Avatar
Hot Property is a GREAT looking boat! I have some pictures of it in a poker run but I can't find the file. One of my favorites.
XPRESS 33PP is offline
Old 08-26-2006 | 06:48 PM
Thanks for the free press XPRESS.
trader1 is offline
Old 08-27-2006 | 09:56 AM
Found a picture
Old 08-27-2006 | 10:49 PM
Did the boat come from the factory with the HP500's? Did they require a rebuild a2 240-260 hours?
ActiveFun is offline
Old 08-28-2006 | 04:46 AM
Hi Active,
The boat came from the factory with 500efi's. The problem was with the CMI headers leaking. From what I understand this happens often with these headers. I also think the previous owner did not flush as often as needed. Assumptions but evidence points that way. I do think it was a little soon as well but I figured do it right insted of patching it. So basically it a new boat now. Interested???
trader1 is offline
Old 08-28-2006 | 07:47 PM
I have a friend with a 99 Powerplay that had the same problem. 260hrs and 2 new sets of headers and 1 valve job. Luckily it was caught early because the leaking header destroyed the exhaust valve stems, and it was ready to drop a valve! Glad to see you are getting the boat back together Matt.Do you think you will take it to Cambridge? Good luck,Donnie
PPlay33 is offline
Old 08-28-2006 | 09:06 PM
Hi Donnie,
I am going on the Cambrige weekend. Are you guys going? Thanks I am excited to get it back. Should be running Saturday, are you going to be around?
Matt
trader1 is offline
