Anyone running this 509" combo? >
Old 08-25-2006 | 09:20 AM
Default Anyone running this 509" combo?
If so how much estimated horspower/ torque? Started out as a 502 mag.
509c.i., 088 rec port heads w/ 2.25int, 1.88 ex valves, bowl ported. Crane roller rockers and hardware. Crane 731 rollercam. MPI intake setup.lightning headers.
Dyno#'s would be good but a guesstimate will work too.
kennyo is offline
Old 08-25-2006 | 11:37 AM
jdnca1's Avatar
Default Re: Anyone running this 509" combo?
I would guess around 500-520....probably pick up a little from being a 509 and give a little using MPI system. Put intake and carb on and might see 550ish. Cam is too small to benefit from twisting the motor above 5500....
jdnca1 is offline
Pat McPherson's Avatar
Should make about the same power as a HP500EFI.
Maybe just a little more with the ported heads and added cubes...
Patrick
Pat McPherson is offline
Old 08-25-2006 | 12:09 PM
[QUOTE=jdnca1]I would guess around 500-520....probably pick up a little from being a 509 and give a little using MPI system./QUOTE]
I would very much agree with these numbers. I have a lightly ported MPI intake, Dart Pro1 heads, a slightly larger camshaft, and 9.5:1 compression. Mine made 540HP on Lingenfelter's dyno between 5200 and 5300 RPM.
BGIII is offline
Old 08-25-2006 | 01:16 PM
Wobble's Avatar
SORE MEMBER
What's the prize?
My guess is 530
Wobble is offline
Old 08-25-2006 | 02:20 PM
mjb
I'm running similar engines in my top gun except I'm using ported dart heads, a slightly larger cam, 9:1 compression, modified mpi intake manifold and redesigned fuel system.
I'm running about 540+ HP at 5400 RPM's.
mjb is offline
Old 08-25-2006 | 02:26 PM
mjb,
How is your intake modified? How did you do your fuel system?
BGIII is offline
Old 08-25-2006 | 03:05 PM
mopower's Avatar
Toxic FORMULA
A friend has almost that identical engine , 509 , 731 Cam only carbed with a 750 Holley that dynoed 535 hp @ 5400
mopower is offline
Old 08-25-2006 | 03:14 PM
This is my engine combo using the azsm type mpi lower intake and an M3 s/c procharger. I was just wanting a ballpark figure for bench racing purposes. I appreciate the responses.
kennyo is offline
Old 08-25-2006 | 03:27 PM
mjb
BGIII- my manifolds have shortened runners that were also extrude honed by ASM. I scraped the entire cool fuel system. Now I have 1/2" pickups with #8 lines from my tanks to RAMCO fuel/water filters, then #8 to WELDON 600 pumps, thru check valves and #6 to WELDON filters and then to the front of the fuel rails and out the back to WELDON regulators with mechanical psi gauges then #6 returns thru fuel coolers and back to the tanks. I probably could have omitted the fuel coolers since I went back to the tank but they can't hurt. It was an expensive fuel system(x2) but good insurance and maybe a few MPH.
Hope that info helps
mjb is offline
Fast Shafts
OPA/The Jersey Boyz
8
03-31-2008 04:38 PM
tomas_wallin
39
07-24-2007 07:54 AM
tomas_wallin
6
05-03-2006 06:25 AM
Wardey
03-31-2005 01:26 PM
Firewalker
15
07-01-2003 01:51 PM
