How To Bypass Omc Shift Assist??????? >
Old 08-26-2006 | 02:54 PM
Default How To Bypass Omc Shift Assist???????
I've Herd About Bypassing The Omc Shift Assist But Don't Know How. Will This Work With An Hei Distributor??
jamieslib is offline
Old 08-26-2006 | 04:46 PM
Default Re: How To Bypass Omc Shift Assist???????
Petronix distributers come with a diagram to do just such a thing. I will see if I can find that old sheet with the diagram.
OldEliminator is offline
Old 08-26-2006 | 05:49 PM
Scott B's Avatar
It will be a bear to shift however...
Scott B is offline
Old 08-26-2006 | 05:58 PM
The diagram is buried somewhere on the Pertronics website.
Why do you want to bypass the shift assist?
Liberator21 is offline
Old 08-26-2006 | 06:19 PM
mopower's Avatar
Toxic FORMULA
You can't bypass it and still have it shift properly. I converted my point distributor to electronic which required a bypass circuit for that. It protected the electronics from the shift interupter. It didn't bypass the interupter. Could this be what you're after?
mopower is offline
Old 08-26-2006 | 08:06 PM
bowtie's Avatar
You can hook it up like a Mercruiser. The wires out of the switch go to a plug. Pull them out connect one to ground and the other to the - side of the coil. When you shift it will kill the engine for a microsecond to allow it to come out of gear. This works good, I've done it several times.
bowtie is offline
Elite Marine
1
03-23-2007 07:24 AM
fund razor
6
05-21-2004 09:57 PM
kennyo
3
04-29-2004 07:28 PM
Waterfoul
7
07-03-2002 09:58 AM
