350 Mag goes into Guardian Mode - Help Please
Check for a bad neutral safety switch. If they see neutral they will not go over 3000, and will not code. Unplug the switch and see if it fixes it. If it does it may be that the lever that switches the switch is over-traveling and the switch is dropping off the back side. Don't ask me how I know this
Are you sure it's going into Guardian Mode? Is there an alarm when this happens? What codes are currently in memory? What is the frequency count for each one?
You could try clearing the Freezframe memory and retesting. If you get an alarm/Gaurdian Mode again, it should be easy to figure out why after rechecking the memory and reveiwing the newly stored faults.
If you get an alarm and there are no faults stored, there may be a problem with the ECM, but thats not very common.
Taking a wild guess, it sounds like a possible problem with the shift position switch. If the ECM thinks the engine is in neutral, it will limit RPM to 3500. But you should have a stored Neutral Overspeed fault if that was the case. Again, this is just a guess, there are other faults (ECT Overtemp, Low Drive Lube, Low Oil Pressure) that could be causing the power reduction.
Dave
Dave
I had a 350 Mag in my old boat and it did something similar at 3000 rpm. Sounded like the rev limiter kicked in or something. Turned out to be a loose plug wire. Check those, all of them including the main one. That's what it was for me.
hi , ihave a boat with 2 engines 350 mag the 02 engine do not want to turn on i scanned the engines i have the following code on both of them
Current ECM Codes
Sensor Fault, click Read Fault button for details
Trouble Code List:
PITOT CKT LO Code is active
FUEL LVL CKT HI Code is active
STEER CKT LO Code is active
SEA TMP CKT HI Code is active
TRIM CKT HI Code is active
i test the injectors with the diacom from 01 to 04 injector test good, but from 05 to 08 i cannot test them ,the same result on the 02 engines,please let me know if you have any suggestion.
engine 01:
Parameter Description Value Unit
Engine Speed.......................................... 0 RPM
Available Power..................................... 100 %
Coolant Temperature............................... 75,20 °F
Fuel Flow Rate..................................... 0,00 GPH
Port Exhst Cool Temp.............................. 32,00 °F
Sea Pump Pressure.................................. 0,00 PSI
Starb Exhst Cool Temp............................. 32,00 °F
IAC Duty Cycle..................................... 0,00 %
Manifold Absolute Pressure........................ 14,80 PSI
Trim Position...................................... 1023 #
Baro Pressure..................................... 14,80 PSI
Trim Volts......................................... 4,99 VDC
Manifold Air Temperature.......................... 78,80 °F
Pitot ADC............................................. 0 #
Oil Pressure....................................... 0,38 PSI
Paddle Wheel.......................................... 0 Hz
Throttle Position.................................. 0,00 %
Sensor Power....................................... 5,06 VDC
Throttle Sensor Voltage............................ 0,63 VDC
Lake/Sea Temp..................................... 32,00 °F
Spark Advance...................................... 8,00 DEG
Fuel Level......................................... 1023 #
Battery Voltage................................... 11,25 VDC
3. TROUBLE CODE STATUS
Current ECM Codes
Trouble Code List:
engine 02
2. PERFORMANCE DATA
Manifold Absolute Pressure........................ 14,57 PSI
Baro Pressure..................................... 14,57 PSI
Oil Pressure....................................... 0,54 PSI
Sensor Power....................................... 4,99 VDC
Throttle Sensor Voltage............................ 0,64 VDC
Battery Voltage................................... 11,11 VDC
Current ECM Codes
Trouble Code List:
there is pressure on the fuel pump the startor good spark plug new the fuse good thank you to help me
best regards
Current ECM Codes
Trouble Code List:
engine 01:
Current ECM Codes
Trouble Code List:
engine 02
2. PERFORMANCE DATA
Current ECM Codes
Trouble Code List:
best regards
