back fire/ miss ??? >
back fire/ miss ???
back fire/ miss ???
Old 08-27-2006 | 08:04 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Default back fire/ miss ???
I have two 588 ci N/A motors and the starboard motor seems to backfire or miss while cruising. It seems to do it the most around 3500 rpms. It will not make the noise at idle. What could it be? The motors have very low hours. The motor runs great and doesn't loose power, just makes funny noise.
Thanks!
mcraymond3 is offline
Old 08-28-2006 | 12:57 AM
Default Re: back fire/ miss ???
Loose carb/bolts.
Maybe getting air in the fuel line....do you see your fuel psi drop at or right before the pop?
If your running MSD ignition, make sure you have the vented style caps....Mine were not, and had rust/corrsion inside.
Good luck, let us know what you find.
Back4More is offline
Old 08-28-2006 | 01:15 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
two of the plug wires had small cuts in them. I am replacing all the plug wires and plugs. Which are the best plugs/ wires to use?
thanks!
Old 08-28-2006 | 10:59 PM
I have the MSD wires...never had a problem with them.
Old 08-29-2006 | 08:01 AM
Might be a lean condition. A rocker arm adjusted to tight? Had this happen with mine. Figured it would of showed up initially, but it showed up about after 4-5 hrs. Also, maybe a weak or broken valve spring. I know you said they have low hours, but just a thought. If it only does it at mid throttle only, disregard the last two ideas.
88Fountain is offline
Old 08-29-2006 | 03:56 PM
blue thunder's Avatar
Taylor spiral pro wires from Summit or jegs. If this is carbed I would be thinking jetting in the primarys or wrong power valves. If fuel injected how is fuel pressure when the noise starts?
BT
blue thunder is offline
Old 08-29-2006 | 09:35 PM
mcraymond3's Avatar
Commercial Member
Commercial Members
Is it ok to use NSG plugs? the motors run fine now. Thanks for all the help!
Old 09-14-2006 | 05:04 PM
bad gas try octane booster untill next fill up change water sep.
osen007 is offline
Old 09-15-2006 | 08:06 AM
BillR's Avatar
OSO Moderator
Ethanol fuel issues?????
Been a few of those around here. Fuel filters clogging, pumps having issues etc. Just a thought. . . . .
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR is offline
Wildchild212
9
05-24-2006 08:45 PM
drewwilliams
5
05-09-2006 10:47 AM
dreamer
12-16-2005 08:03 AM
micky dee
4
04-18-2004 08:10 PM
Hauling Trash
06-04-2002 11:42 AM
