2004 6.0L problems ??
Old 08-28-2006 | 07:12 PM
45sonic's Avatar
Post 2004 6.0L problems ??
I currently have a 2004 F-350 crew cab dually with a 6.0L diesel and automatic trans. For about the past 2 or so months I have been experiencing a bucking or hesitation problem. At times I have had the truck stall on me when coming to a stop orwhen putting it in gear. It does refire but still continues to run rough. This condition does not happen all the time. The dealer has had the truck in four different times. First time was to reprogram the computer with a newer program. The next time was something to do with the ISR ???? and a fuse. We have changed fuel/water separtors 3 times and no change.
This time they are at a loss. No codes and no check engine lights.
Anyone else have the same problem??
45sonic is offline
Old 08-28-2006 | 08:24 PM
Son of a Gun's Avatar
Default Re: 2004 6.0L problems ??
Transmission?
Son of a Gun is offline
Old 08-28-2006 | 08:39 PM
Registered User
EGR valve is dirty. It's on the top of the motor right in the front. They need regular cleaning or even better, disconnect it and have a better running truck. We had a whole big string on this about a month ago
http://www.offshoreonly.com/forums/s...d.php?t=135878
Chris Sunkin is offline
Old 08-29-2006 | 05:48 AM
Jassman's Avatar
Correct.
Jassman is offline
Old 08-29-2006 | 11:08 AM
NJSONIC's Avatar
There is a pipe that needs to be cleaned out also.
NJSONIC is offline
Old 08-29-2006 | 07:37 PM
BRUCE SEROFF's Avatar
There has been a couple recalls with regard to the fuel injection module and bad injectors.
I was experiencing the same problem. Brought it in and they took care of it. I had 1 bad injector. All was covered under warranty less 100 ded. because i have 60k on the truck.
BRUCE SEROFF is offline
Old 08-29-2006 | 11:34 PM
I also have an 04 that had the same problems. Call me, I have an ACE mechanice at Battlefield. Scott 703-90606677
P S Mine was a turbo problem
Scott Ferguson is offline
Old 08-30-2006 | 01:07 PM
Bigracks's Avatar
Size Matters
Clean the EGR valve, then use the ford recomended fuel additive, Yes I know that I do not like using additives either, BUT SINCE i started using the ford fuel additive I have had no problems with the EGR valve sticking. 40,000 on a 05 exursinon.
AFE INTAKE, MBRP SS Exhaust, Diablo sport in tow tune.
12 mpg towing 10,00lb @ 75 mph
No tow 17mpg and thats with me racing everybody that lines up to me, it is a 8000 lb truck!! I leave everbody in a cloud of smoke!!
Bigracks is offline
Old 08-30-2006 | 07:45 PM
DirtyMoney's Avatar
Injectors, I have five of these and all have had injectors at least once and two of them twice now with less than 100k miles
DirtyMoney is offline
Old 08-31-2006 | 11:15 AM
Wobble's Avatar
SORE MEMBER
There are 99 Technical Service Bulletins out on the 6.0 powerstroke engine (at last count)
Good luck
Wobble is offline
