Arneson Drive on Velocity 22 >
Old 09-02-2006 | 01:15 PM
jdcorbitt3's Avatar
Default Arneson Drive on Velocity 22
I am thinking of putting an Arneson drive on my Velocity 22. Has anybody done this yet?
John
jdcorbitt3 is offline
Old 09-02-2006 | 04:33 PM
Revelocity's Avatar
Default Re: Arneson Drive on Velocity 22
While I've heard that transmissions have been fitted into the 22' engine compartment - I would guess they came from the factory with a different gas tank location to allow the engine to mount more forward. I think retro fitting an arneson drive would be major science project - if even possible.
Revelocity is offline
Old 09-05-2006 | 11:32 PM
i m starting an install on a 280 next week, should be good.
joeypearce is offline
Old 09-06-2006 | 07:36 PM
ls1nova's Avatar
Doesn't arneson make a bravo conversion kit that doesn't move the engine forward?
ls1nova is offline
Old 09-07-2006 | 12:38 PM
Revelocity's Avatar
Frank - I think you're right on the external tranny. The next concern I'd have would be hanging an extension box (with tranny inside) and then the drive off of a 22' hull. That's a lot of weight levered off the back of the hull. I also have a 22' (older one) and its lay up is very light so some transom reinforcement would be required. You'd also have to question the revised center of gravity of the hull and what impact that would have on handling. The extra lift of the Arneson may help the balance but then again the set-up just might not work. At minumum I'd talk to Steve Stepp before going too far on this. Also, I heard the Arneson (with inside tranny) worked well on the 26'. In any case, I hope the projects are successful!
Rick
Old 09-07-2006 | 03:18 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Rick
If the transom is strong enough for the current outdrive it will be strong enough for the Arneson.
There is not that much of a difference in weight between the two and as you noted it would be beneficial to the cg of the boat.
Rik is offline
Old 09-10-2006 | 10:59 AM
Is this a newer 22 or and vintage one? Do you have the drive?
It seems like big bucks to sink into a 22. If you're looking for the high X dimension you could pick a blackhawk...cheep. They had there issues but they were mostly related to heavy hulls. This would help with the weight issue.
my 22 was pretty fast with a 400hp outboard and the prop even with pad.
I'd love to see a 600hp small block with a high X level....Hold for dear life
good luck with the project keep us posted on it.
steve
Vicious22 is offline
Old 09-10-2006 | 01:19 PM
tblrklakemo's Avatar
SeaRay Sundancer
check out the little donzi w/ the arneson. That should be a gold mine of info on your project. That guy posts on OSO but i cannot think of his name. What about a pulse drive...much more friendly if you ask me, and they have several small single engine applications documented on their website.
tblrklakemo is offline
Old 09-11-2006 | 02:26 PM
jdcorbitt3's Avatar
It's an 88 that has had the stringers reworked. It has a 7.4L 330hp Merc. I may put an LS2 smallblock in. I am getting the drive used so i'm not too deep into it. As far as CG, It may move it a half inch back, but a 200lb pax will bring the CG foward again.
Rik. How much is a Bravo box?
John
Old 09-11-2006 | 09:08 PM
The Boyz From Arneson Know The Guy With The Donzi. Their Are Some Photos Of The Boat In Screamandfly Along With Some Vids
z.zuperboat is offline
