Mercury 525 EFI Steaming
I have a pair of Mercury 525's EfI's and the Starboard engine has steam and water coming out of the exhaust. The water temp is 140 and the oil temp runs between 180 and 215. I also have an engine alarm that goes off with 5 long beeps that have 5 fault codes for different things. A Map Sensor fault came when I had a dealer check the alarm codes. I replaced the Map Sensor and the alarm problem went away for a while but nowI am having the alarm with 5 long beeps coming on and also the vapor detector beeping and red light coming on. I would certainly appreciate any suggestions or help in resolving these problems.
Thanks,
Boyce
Thanks,
Boyce
Don't know much about the 525's and the alarms, but it sounds like you need to leak check your headers. If it's not the headers, then it's probably a leaky intake manifold gasket. The headers are easier to check.
Rene
Rene
Rene
Rene
Are you thinking of checking these because of the steam?
Neither I am familiar with the alarms on a 525 EFI but steaming exhaust is often related to low flow of water. Could be the water pump or anything restricting the flow like old impeller blades, etc
Yes, I was talking about the steam. Low flow can cause this but it will usually be accompanied by a high temp condition. If your temps look good at WOT, then it's probably a water leak.
Rene
Rene
Rene
Rene
If you have a restriction somewhere you can have good pressure but unsufficient flow. I had the hose between the transom and the outdrive go bad. It steamed enormously and fellow boaters thought the boat was on fire and offered me assistance. Still the engine temp and the water pressure was OK
tcm07
10-03-2008 02:00 PM
