Motion owners check your tanks !! >
Old 09-04-2006 | 10:40 PM
berns29scarab's Avatar
Default Motion owners check your tanks !!
Unsure if all are like this or just certain years etc...
I have a buddy of mine with a 35 unsure of the year an early 2000's i believe and he just found out his fuel tanks are similar to skaters and are fiberglassed in the boat...NOT A SEPERATE TANK. The new ethanol fuel is giving him much grief as it is softening his tanks. Just a heads up to help avoid the mechanical nightmare he's been going thru. He's now deciding between installing bladders or installing new tanks.
berns29scarab is offline
Old 09-04-2006 | 11:05 PM
LubeJobs42's Avatar
Default Re: Motion owners check your tanks !!
I have had problems for years. He needs to remove the sending unit, presure wash the bottom of the tank and vacuum it out. The right way is to cut the lid off and epoxy the whole tank. You can check to see if your having a problem by removing the fuel fiter and see if there are gold color pieces of epoxy. It looks like strips of varnish when it peels. It is the worst design in the world. Once you fix it right you should be ok.
LubeJobs42 is offline
Old 09-04-2006 | 11:07 PM
LubeJobs42's Avatar
Have him call Larry Goldman of Xtreme Marine 305-947-3278 or 954-610-2260. He is an expert with any Motion issue. I'm sure He has several solutions for your friend.
Old 09-05-2006 | 06:13 AM
Phantom1's Avatar
Skater uses fiberglassed fuel tanks????
Phantom1 is offline
Old 09-05-2006 | 06:14 AM
dockrocker's Avatar
There's a whole lot of info on ethanol and 'glass fuel tanks over at a the Boat US website - they've actually got a separate forum set up just for ethanol issues. www.boatus.com
dockrocker is offline
Old 09-05-2006 | 08:28 AM
thanks i'll pass on the info
Old 09-05-2006 | 09:57 AM
LubeJobs42's Avatar
It's not actually a tank. The section off and area of the hull, epoxy it and put a lid on it. Worst design in the world. I had more problems then I could count until I had it repaired properly.
Old 09-05-2006 | 10:14 AM
Ryan Beckley's Avatar
Racer
Racer
Skater has always used this desing without much issue until the ethonol came out. My 1987 24' has built in tanks with no problems.
Ryan Beckley is offline
dozer1
Motion
20
12-22-2021 05:46 PM
stecz20
Cigarette
247
03-17-2012 09:16 PM
berns29scarab
Motion
0
09-04-2006 10:38 PM
Vyper340
Powerquest
97
12-13-2005 08:51 PM
tpmarine.com
Baja
4
07-18-2005 06:54 PM
