Engine building guru ?'s >
Old 09-05-2006 | 04:17 PM
nordic95's Avatar
Default Engine building guru ?'s
Hey pros just have a couple of questions reguarding engine machining 101.
1)If an engine block was line bored, how long of a running time before dimensions would or could change?Would all caps be the same demension?or could one or two be different?
2)When disassembling a short block and you noticed a bent rod,would you check the bore for damage and could a bent rod cause a cylinder to go out of round? If the cylinder was on the border of SO-SO would you take the time to fix it right or just slap it together?
Thanks way in advance
Nordic95
nordic95 is offline
Old 09-05-2006 | 04:28 PM
nordic95's Avatar
Default Re: Engine building guru ?'s
Originally Posted by SB
Well, if I remember by your pictures when the cam was being degreed and it was going back together, it doesn't look like really any machining was done. You could still see the headgasket imprints like the heads where just removed after some years of use.
So....my off the wall guess - from the pics your original builder posted - is that no machining was done.
I mentioned this before on the other thread.
Sincerely,
just another backyard mechanic
These are just "IN GENERAL" questions.They could be "MY FRIENDS" blocks that I am asking about.
Nordic95
nordic95 is offline
Old 09-05-2006 | 04:30 PM
SB
Deleted - you may want to change my quotes. Sorry.
SB is online now
Old 09-05-2006 | 04:36 PM
nordic95's Avatar
I was kidding Put them back up silly. I need answers to my engine building woes,but I have to be a gentlman about it,no name calling or pointing fingers.I appreciate all the info you guys provide.I just trying to figure out why I went from,"you just need a valve adjustment"(old builder) to "the machine work on these blocks s--k" we need to do it right this time(this was from new builder).
Nordic95
nordic95 is offline
Old 09-05-2006 | 05:44 PM
nordic95's Avatar
Here is a picture of the rod that came out of the damaged cylinder that was over looked.Would this cause the out of round condition that would also oil down this cylinder?This rod came out of the stock running motor during the first build.
Nordic95
nordic95 is offline
Old 09-05-2006 | 07:03 PM
Wow
otis311 is offline
Old 09-05-2006 | 07:22 PM
nordic95's Avatar
Originally Posted by otis311
Wow
You spelled that backwards,DUMMY.
Nordic95
nordic95 is offline
Old 09-05-2006 | 07:37 PM
Its upside down MOM
otis311 is offline
Old 09-05-2006 | 07:55 PM
articfriends's Avatar
When I look at the picture of the rod it looks like it has stock rod bolts and nuts. Arp nuts are usually 12 pt on connecting rods and most aftermarket rod bolt nuts are also black or polished looking from the extra treatments they get,not browish rust colored. Sounds like your "friend" needs some serious motor work to straighten out "his" problems he has found,Smitty
articfriends is offline
Old 09-05-2006 | 08:00 PM
nordic95's Avatar
Thats what it is turning out to be,only a couple of hours run time after full machine work and rebuild now its back out and needs all machine work done again to make it right,almost sound like "He" got ripped off and didnt get what he paid for from first builder.But thats just my opionon.
Nordic95
nordic95 is offline
