4 Wheel Drive Question
Old 09-08-2006 | 03:30 PM
Tony Montana's Avatar
The BAD Guy
Default 4 Wheel Drive Question
I just bought a new 06 F-250ps 4x4. My question is proper use of the 4 wheel drive. It has a manual transfer case. The question is on the front hub locks the proper use? Owners manual only says to make sure both wheels are in locked or free position before engaging into 4 wheel drive. I had a few people give me a guess on how it works but I would like to know for sure. So if you know 100% how it works let me know. Thanks
Tony Montana is offline
Old 09-08-2006 | 06:36 PM
Re: 4 Wheel Drive Question
i'm not shure but if the lock's are there.....there's got to be a reason..
lock it or loose it
good luck
mikebrls is offline
Old 09-08-2006 | 07:24 PM
Default Re: 4 Wheel Drive Question
keep in free position , unless in 4 wd or you will be buying $400 bearings.
Scott Ferguson is offline
Old 09-09-2006 | 05:09 AM
David's Avatar
Yep- keep hubs in unlocked position for normal use. If you want/need to use the 4x4, then lock the hubs, and shift her into 4H or 4L depending on the situation.
David is offline
Rookie
5
05-04-2006 05:03 PM
plumbers crack
6
11-25-2005 07:06 PM
Waterfoul
11-25-2003 10:25 AM
