Prop and speed calculator >
Old 09-09-2006 | 07:47 PM
Default Prop and speed calculator
Can someone post the calculator for prop, rpm, and gear ratio calculations.
RBeyer is offline
Old 09-09-2006 | 07:56 PM
Default Re: Prop and speed calculator
http://www.go-fast.com/bam_marine_knowledge_base.htm
This what you are looking for, or the formula?
Hydrolift is offline
Old 09-09-2006 | 08:54 PM
The formula
RBeyer is offline
Old 09-10-2006 | 09:14 AM
Originally Posted by RBeyer
The formula
(Pitch x RPM) / (Reduction x 1056) = MPH.
Doug
Boatally Insane is offline
Old 09-10-2006 | 09:59 AM
Doug
I'll bet you can calculate the #s is your sleep by now
Kidnova is offline
Old 09-10-2006 | 10:58 AM
Thanks, I used to have it and lost it.
RBeyer is offline
Old 09-11-2006 | 05:48 PM
Merc. has had a "slide rule" calculator available that lets you check everything quick and easy. The Merc. part # is: C-90-86147, and includes some real good, basic, "don't kid yourself" instruction. Hope that # is still available cause it eliminates just so much B.S.! --- Jer
jpclear is offline
Old 09-12-2006 | 11:38 AM
This site is pretty cool.
http://www.rbbi.com/folders/prop/propcalc.htm
jeffswav is offline
Old 09-13-2006 | 09:35 PM
Nice site. Thanks
RBeyer is offline
Old 09-16-2006 | 03:05 PM
Strip Poker 388's Avatar
Rob
Originally Posted by jeffswav
doesent work for above 100mph
Strip Poker 388 is offline
