502 cam specs please >
Old 09-12-2006 | 07:27 PM
GoCiggie31's Avatar
From: Where the water meets the oaks 'n Pines in the Sierra Nevada's of NorCal
Default 502 cam specs please
I am rebuilding my port engine of my 502 carbed 415hp Tmercs and was wondering if anyone has the specs to the oem mercruiser camshaft. Would anyone have a crane part number equivalant or suggestion?
engine in question is serial number 0f077723
trying to match oem stb engine(07077715) and get the boat back in the water to finish up the season
Many Thanks
gociggie
GoCiggie31 is offline
Old 09-13-2006 | 06:54 AM
Default Re: 502 cam specs please
If it is flat tapit cam I have 2 brand new take outs
brian41 is offline
Old 09-13-2006 | 08:52 AM
I have the stock roller out of a 97 502 mag mpi. It looks like new,I'll take $125 for it. I also have all the hardware of the heads.
kennyo is offline
Old 09-13-2006 | 10:02 AM
SB
Go to Bam's site www.mercruiserparts.com , go to engine look up tables, find your engine and it's camshaft part # and then look below. Disclaimer: these are my notes from other sources and being human I am wrong sometimes.
Mag BBC 454/502 Flat Tappet (rect heads)
.004” 296*, 296*
.006” 286*, 286*
.050” 224*, 224*
.200” 130*, 130*
Valve lift with 1.7 .510”, .510”
LSA 115.5
Merc Part#431-9830 / GM#14096209
ICL 114 ATDC
ECL 117 BTDC
GM Part#10185060 (same as above but ground with 5 degrees advance)
ICL 109 ATDC
ECL 122 BTDC
Merc Mag Roller
Merc# 431-850478 / GM#12551622
.004 300*/ 300*
.006 288*/288*
.050” 225*/225*
.200” 125*/125*
Lift .483”/. 483”
ICL 109*
LSA 115.5*
SB is online now
Old 09-13-2006 | 10:09 AM
GoCiggie31's Avatar
Thank you for the info
searaycer
Do It Yourself, Boating on a Budget
5
09-13-2008 11:04 AM
Smitty
10
03-11-2005 07:42 AM
Kanookstr
25
01-13-2004 08:47 PM
obnoxus
2
02-18-2003 06:04 PM
Aces & Eights
1
07-23-2002 02:08 PM
