Procharger Question
Can anyone tell me the difference between an M1 and an M3? I know the M3 has the bigger aw504 intercooler instead of the aw324 but are the units themselves different? I have an M1 now running about 6psi. The reason I ask is id like to put the bigger intercooler on but they are very expensive, ive got a line on an M3 an aw504 intercooler. Would it be any advantage to change to the M3 unit if I still run 6psi? Would it make 6psi more efficiently???
The M3 is bigger size charger. Both is size and volume of air that it will move. Procharger did not want to give out any of it's specs when I had asked them before. Do not know for sure but I would say that the M3 will not have to turn as fast or hard to give you the same boost with less heat, plus with bigger intercooler you will have even less heat, thus more usable HP. You could just get a rtech intercooler and this will give you more HP also. Do a search on rtech. Tom has done a number of test showing the increase HP wih just changing to his intercooler.
The M3 is bigger & more efficent & can spin slower than the m1 to produce the same boost on most applications. They also make M4's & 5's.. They also have a 648 series intercooler available.. Also you want to stay self contained. The 504 is a bigger intercooler and the 648 even bigger. Yes the brackets for the M3 are different to accomodate its size difference.. I dont do used stuff, but if you need anything new from Procharger I am a distributor & installer for them...
Jamie / Lakeside
Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
Jamie / Lakeside
Jamie / Lakeside
Which engine model do you have.. The 504 intercooler protrudes about 2" more forward than a 304 intercooler does on most applications... I Hope this helps you..
Jamie / Lakeside
Jamie / Lakeside
The most cost effective ($/HP) thing for you to do is install an Rtech supercooler upgrade for Procharger M1 systems. Keep the M1, don't change the pulleys and you will see another 2 psi boost in the intake manifold and another 90 HP on the dyno. Most of this gain is due to lower restriction to air flow from blower to intake, not reduced air temperature, although we see a drop of 25F compared to the 324, even with the extra 2 psi of boost. Think about that for a minute; more boost and less heat don't usually happen at the same time and that's the key to the system's performance.
The first Rtech supercooler we ever sold went into service on an M1 system 3 years ago and the guy can't break the M1. A bigger blower may be more efficient but I can't really say for sure because Procharger doesn't publish their compressor maps. But I know it wouldn't add the 8 mph we saw with the supercooler upgrade. Both the dyno test and the water test were covered in articles for Family & Performance Boating.
For the complete story go to:
www.rtechperformance.com
Tomcat -
I am interested in a Rtech Cooler for an M-3 502 EFI Set Up for my 540 I'm building. What do you offer? I can't see anything on your website.
I know you had a mock up version a while back. Did it make it to production? What is the cost?
Kirk
Kirk
Kennyo, its in a 288 and I think i have enough room...its VERY close. If I have to mount it on the side it may not be worth it.
