99' 28 Thunder >
99' 28 Thunder
99' 28 Thunder
Old 09-14-2006 | 02:02 PM
Default 99' 28 Thunder
99' 28 AT hull with trailer, well maintained. Less running gear. How much? Himes
HIMES(JAIME) is offline
Old 09-14-2006 | 02:11 PM
Stormrider's Avatar
JC Performance Engines
Default Re: 99' 28 Thunder
$20-25k.
Stormrider is offline
Old 09-14-2006 | 02:48 PM
cosmic12's Avatar
any pics??? or is it the one with the big power less motor?
cosmic12 is offline
Old 09-15-2006 | 08:02 PM
R Addiction's Avatar
AT Cult Member #3
single or twins? Interesting
R Addiction is offline
Old 09-15-2006 | 08:58 PM
single, what year did AT go to no wood in the 28's, were any other hull changes made from 99 to present. thanks Himes
Old 09-15-2006 | 09:04 PM
cosmic12's Avatar
the hull is now the old 32. pre 2004 boats are not.there are also changes to the dash and cabin. the newer boats have a much flater straighter bottom.look at the pics of Sdaves cockpit and then at mine
cosmic12 is offline
Old 09-15-2006 | 09:59 PM
so SC Daves o4 and yours are same hull right, how much lighter than pre o4, which i assume had wood in them. btw like both you guys paint .
Old 09-15-2006 | 10:08 PM
cosmic12's Avatar
I wish there was a way for you to see the diff up close, the 99 you are talking about is a way different boat. the story I got is the hull was a center console fishing boat with alot of rocker in it. the 04 and newer boats are the old 32 mold with a dam put in it to make 28ft. very stable flat running boats. I had a 99. my trailer was built for the 99 but the 06 fits much better flater and longer. as for the wood I don't know when he stopped useing it in the 28. and yes they are the same hull but diff cockpits and dash
cosmic12 is offline
Old 09-15-2006 | 10:21 PM
thanks Cosmic, i was unaware you used to have a 99. that pretty much answers all my questions. Himes
Old 09-15-2006 | 10:36 PM
cosmic12's Avatar
if you go to the classifieds and go between the 99 and the 04 you can see the diff
cosmic12 is offline
