A couple of pic's from Dubuque this weekend
Sorry about the picture quality...wife was
using her camera phone.
1st one: drive damage to a friends boat,
were thinking manatee impact
2nd one: Running along with poker face at about 86 mph
Man that first picture is NOT good.
I have never seen one broke like that before.
I have a couple of xr lowers forsale if interested. One has about 120 hours on it and is perfect. $1800.00
The other needs to be gone through and checked out. I think it has a little metal in it from a failed upper. It also has about 120 hours. $1000.00
Good Luck
Good Luck
No XR drives are internally different from regular Bravos. In an XR drive the gear ratio is determined by the lowers where as in a regular Bravo the ratio is in the uppers.
Originally Posted by BajaRunner
will xr lowers bolt to regular uppers? whats the weak link?
That would be something similar to what the XZ was.
( X upper with XR lower)
The 15/19 tooth count XR lower( 1.5) is the same tooth
count as the standard bravo lower, so you would have the same ratio.
The only thing I've seen wrong with the standard
lower is propshaft breakage on high x dimensions,
where the prop is running near the surface.
Good Luck
Good Luck
replace the gears in the upper.
After blowing the l/h drive at WOT last weekend,
I'm seriously considering building a spare drive,
I'll keep you lowers in mind.
Are you doing shorties ?
