496 Ho ?
Old 09-22-2006 | 06:08 PM
DORaymond's Avatar
Default 496 Ho ?
Will the 496 HO directly replace a Gen VI 502 MPI? If not, what changes would have to be made?
DORaymond is offline
Old 09-23-2006 | 06:20 AM
DORaymond's Avatar
Default Re: 496 Ho ?
Anyone?
Thanks.
Old 09-23-2006 | 10:35 AM
I did the opposite. Put in a 502 , took out the 496. Everything fit fine for me. Only problem I had was had to move holes in transom a little bit. You should be OK if your just running the rubber exhaust hose, as it will bend over. Check how much room you have in front of your 502. I think the 496 is an inch or so longer, so make sure you have room.
Revd Up is offline
Old 09-26-2006 | 04:27 PM
DORaymond's Avatar
Revd Up- Why did you go from a newer 496 to an older 502? Seems like the newer technology would be better.
Old 09-26-2006 | 07:05 PM
Dave M's Avatar
Veteran: Navy
I went from a 454 Mag to a 496HO. Like RU said, it's slightly longer and higher. I'm using stock exhaust with rubber hose, no trouble there.
I'm pleased with my 496.
Dave M is offline
TeamPSI
23
12-10-2007 05:23 PM
apexer
11
07-20-2007 07:24 PM
westcoaster
3
08-08-2005 11:24 AM
bn
4
01-15-2005 07:40 AM
NVRENOUGH
3
02-18-2002 12:25 PM
