gear drive
Old 09-22-2006 | 07:21 PM
nocigarette's Avatar
Default gear drive
who makes the best gear drive or am i wastig my time and should just go with the jessel belt...................man it is exspensive though///////////
nocigarette is offline
Old 09-22-2006 | 07:37 PM
Default Re: gear drive
best gear drive is RCD, run all the time in my boat, Keith black is ok as well, wouldnt run a belt, I like to wash down and the RCD set up right is bullett proof, good luck ,gg10
gg10 is offline
Old 09-22-2006 | 07:38 PM
Where Due I Find It Thanks Buy The Way
Old 09-22-2006 | 08:58 PM
Reed Jensen's Avatar
Pete Jackson gear drives is a stone's throw from me. But I'd rather run a good roller chain than a gear drive. Jessel belt drives are great for R and D and dyno work, but their life is shorter than a chain. Gear drives impart a different load on the cam bearings. The gears tend to push the cam and crank apart, where the chain tends to pull them together. BBC engines have the oil port for the cam bearings on the "bottom" where the load is placed when running a chain. If you run a gear drive the load is on the top. Some people don't like the gear drives on boats because of the harmonics from the camshaft. Cams tend to "load" and "unload" depending on the cam lobe locations. The energy that is used to depress the valve spring is returned to the cam on the back side of the cam ramp. With a gear drive the gears tend to "chatter" as the energy is returned. Especially if they are straight cut gears and not helical cut. Straight cut gears are more efficient, but by their design the gear faces "impact" each other upon contact and slightly increase and decrease the cam rpm during the contact. That is why modern stick transmissions use constant mesh helical gears. They are smoother and less noisy. I'd suggest you go with a high quality roller chain and forget the gears. Just my opinion.
Reed Jensen is offline
Old 09-23-2006 | 06:42 AM
Thanks Guys
Old 09-23-2006 | 08:39 AM
The Nooky man knows his shizzo.
The guys who certify automotive engines for aircraft use will only use a belt where they can put 2 (i.e. a redundant belt) like on the water pump. The belt driven cams haven't met their standard for reliability. But these are boats and not airplanes so.............
And chains have improved in the last 20 years.
vtec is offline
Old 09-23-2006 | 06:02 PM
Im with reed jenson, been there done that on the others. Brian
scarrab30 is offline
Old 09-24-2006 | 07:18 AM
what roller chain due you suggest
Old 09-25-2006 | 07:45 AM
PatriYacht's Avatar
Cloyes Hex Adjust is good quality and easy to adjust.
PatriYacht is offline
Old 09-25-2006 | 10:05 AM
ratman's Avatar
rollmaster timing chains are the finest made period. the metalurgy of the steel in the german made chain is what separates them from the others, as its the chain that streches over time. rollmaster also use billet gears, and the cool part is they only cost a few dollars more then other timing chain sets. ROLLMASTER
ratman is offline
