Any gains on stock 7.4L from thru-hull exhaust? >
Old 09-24-2006 | 04:29 PM
Default Any gains on stock 7.4L from thru-hull exhaust?
330HP stock engine.
Would i see any gains from a straight through hull exhaust?
LS1 MOLESTER is offline
Old 09-24-2006 | 06:10 PM
Default Re: Any gains on stock 7.4L from thru-hull exhaust?
Most likely you will see a gain. Probably 100 or so rpms.
Griff is offline
Old 09-24-2006 | 09:23 PM
can i get a ball-park number for the cost of buying and installing a run of the mill thru hull system?
Old 09-25-2006 | 12:12 AM
All you really need is the exhaust hose and a pair of exhaust tips--probably about $300. You can leave the Y-pipe in place and cap the ends. Then you need a hole saw to cut the holes for the tips. Get a transom template so you can cut the holes in the proper location. If you want it to be a switchable/silent choice system then you will need some diverters and it will get a lot more expensive.
Griff is offline
Old 09-25-2006 | 08:04 AM
I had a 7.4/330 in my boat when I 1st got it. I'd get another +,-150 R's and 1-2 more mph when I flipped the switch from thru prop to thru transom.
Like Griff said, if you do the install yourself be sure and get a template to locate the transom holes. You want the "standard Bravo" location (that the right name for this you guys?). Previous owner, or installer, drilled the transom holes about 3 inches higher than standard on mine to make up for the 3 inch spacers between the manifolds and risers in the Merc exhaust. Now I have a set of KE's sitting in my basement that I can't use, until I plug the existing holes, and drill out new ones
Kidnova is offline
Old 09-25-2006 | 08:07 AM
mats's Avatar
My guess is that you may gain 100 rpm at the most. The most significant difference will be the noise, which is a matter of taste. Having unsilenced through hull exhaust 100% of the time is to many people really tiresome . An option would be silencers and/or cutouts. But then the $$ starts rolling....
mats is offline
Old 09-25-2006 | 05:37 PM
cuda's Avatar
You can usually find a good set of diverters pretty cheap. I was going to buy a pair one time for $150, but I went a different direction.
cuda is offline
Old 09-25-2006 | 06:33 PM
Same engine same result.
Hydrolift is offline
Racerngr1
03-05-2009 10:14 AM
Ateco
Great Lakes and Canada
0
05-12-2006 09:52 AM
Harper220
01-03-2006 09:24 AM
tommymonza
09-07-2005 06:28 PM
27 FOUNTAIN
15
02-19-2002 08:39 PM
