140*F Thermostat for Merc 496 >
Old 09-25-2006 | 01:50 PM
Rage's Avatar
Default 140*F Thermostat for Merc 496
Where can I get a 140*T thermostat for a Merc 496?
Rage is offline
Old 09-25-2006 | 04:55 PM
Reckless32's Avatar
Rough Seas Lie Ahead
Default Re: 140*F Thermostat for Merc 496
Why 140* and not the factory 160*??
Reckless32 is offline
Old 09-26-2006 | 08:48 AM
Rage's Avatar
Cooler air more power.
Rage is offline
Old 09-26-2006 | 10:43 AM
Wobble's Avatar
SORE MEMBER
140 is the stock t-stat for many mercruiser motors with fresh water cooling. West marine (Sierra Brand) should have them as will most marine type stores. Don't use the automotive type.
Here is cp's one http://www.cpperformance.com/detail.aspx?ID=695 dont know if it is the right size for a 496, but I assume that it is.
Boaters world http://www.boatersworld.com/product/356330951.htm
Wobble is offline
Old 09-26-2006 | 11:27 AM
Reckless32's Avatar
If the factory designs them (496's w/ closed loop cooling) to have the 160* thermostat,, wouldn't running the pistons cooler impact the the fuel/air combustion properties? maybe causing carbon buildup on valves etc due to lack of a clean burn?...assuming nothing else has been modified.
Old 09-26-2006 | 12:43 PM
140* water temp won't make the intake air any cooler. Its set up to maintain constant temps with a 160* and the best performance.
Griff is offline
Old 09-26-2006 | 01:00 PM
Rage's Avatar
Thanks!
Rage is offline
Formula311-SR1
14
10-22-2007 02:49 PM
paradigm shift
3
06-12-2006 07:43 PM
RonS
1
08-20-2005 04:13 AM
Dusty Times
1
05-23-2004 03:05 PM
cooltoys61
4
05-13-2004 06:41 AM
