Gen V heads on early 454 block >
Old 10-01-2006 | 12:50 PM
Default Gen V heads on early 454 block
Will 088 heads off a GEN V 502 fit on a early 454 block with casting #361959
jdub is offline
Old 10-01-2006 | 05:46 PM
BY U BOY's Avatar
Default Re: Gen V heads on early 454 block
Check Piston Clearance
BY U BOY is offline
Old 10-01-2006 | 05:48 PM
JCPERF's Avatar
No
JCPERF is offline
Old 10-01-2006 | 06:12 PM
JC could you give me the short on why?
jdub is offline
Old 10-01-2006 | 06:19 PM
JCPERF's Avatar
The water jackets are not compatible.You can use mark4 heads on a gen5or6 block but not the other way around.
JCPERF is offline
Old 10-01-2006 | 08:32 PM
OK... will GEN V heads fit on GEN VI block? Thanks.
jdub is offline
Old 10-01-2006 | 08:36 PM
JCPERF's Avatar
Yes
JCPERF is offline
Old 10-01-2006 | 08:42 PM
thanks
jdub is offline
Old 10-02-2006 | 02:26 PM
I was told the same thing JC said. I am running Mark IV heads on Gen V Block, so far so good. No overheating at all.
jeffswav is offline
Old 10-02-2006 | 04:00 PM
birdog's Avatar
Just buy my fresh MKIV style 188 heads...
Frsh with Inconel/Stainless valves..ready to run
birdog is offline
Monkey Spanker
13
12-31-2005 04:34 PM
baja226s
4
11-16-2005 06:58 PM
QUIKDECISION
2
04-25-2005 09:20 PM
pacedog
6
07-06-2004 11:06 PM
blown formula
3
01-08-2003 02:28 PM
