1st Drive........New 30 Spectre >
Old 10-01-2006 | 11:19 PM
Default 1st Drive........New 30 Spectre
Gentleman -
Just spent the day in my new (to me) 30 Spectre (2000 model) with twin 300 Promax's. What a blast!!!!!!!!!!! I love it already.
One question.......Spinning 14.5 X 32 Merc Lab Cleavers, full tanks of fuel and four adults in the boat, running into a 10-15 MPH headwind, the boat ran 90 MPH on GPS. That was the best run of the day. Freshwater lake and probably one foot whitecaps. The other wide open runs, running with the wind, crosswinds, etc... all gave speeds of 85-88 MPH. I didn't touch the trim at all. There was a red line (tape by previous owner) on the trim gauge, which is where I left it.
Forgot to mention, with the tunnel tab down, it got out of the hole easily. Someone had mentioned that the tunnel tab did nothing for holeshot, but it sure made a different with mine today. No bow rise and minimal cavitation.
Anyway, does this sound about right? I think I'm hitting the limiters, because I could pull back a 1/2 inch on "the sticks" and the boat actually picked up 1-2 MPH. I guess I was expecting speeds in the 95-100 MPH range?
I'm going to be buying a new set of props and use these as a spare. Recommendations? I'm thinking either 15 X 34 or 14.5 X 34 Merc Cleavers.
Thanks.
Mike Sufka
St. Cloud, MN
mikesufka is offline
Old 10-01-2006 | 11:38 PM
Default Re: 1st Drive........New 30 Spectre
I run 32x15 cleavers on a 24ft Liberator cat with 99 300 Promaxs. It runs 106-108. You should'nt be on the limiters. I always use 15's. They slip less. If you go to 34's, it will be a turd. What's your rpm? You may want to go to 15x30's. Good Luck
WILDMAN is offline
Old 10-01-2006 | 11:51 PM
berns29scarab's Avatar
are they 300x's or promax's. on my 30 spectre with 300X's spinning 15x32's NO TAB 6400 rpms ran 107.4...im now running 14 1/2 x 30's at 6700rpms at 102
berns29scarab is offline
Old 10-01-2006 | 11:52 PM
you should raise the tab up once on plane
Attached Thumbnails 1st Drive........New 30 Spectre-4-23-06-spectre.jpg   1st Drive........New 30 Spectre-4-23-06-gps.jpg   1st Drive........New 30 Spectre-my-spectre.jpg
Old 10-01-2006 | 11:53 PM
with my 14 1/2's im on the limiters
Old 10-02-2006 | 07:05 AM
Forgot to mention, RPM was ~ 6100-6200 on the tachs. The boat ran up to about 85 MPH pretty easily, but after that, it seemed to hit the wall. Go bigger or go smaller? Like I said, it seemed to get out of the hole easily with all that weight, thats why I thought I could go bigger?
Mike
Old 10-02-2006 | 07:17 AM
dreamboater's Avatar
Mike
Your slip %is around 20......thats really high. Not sure if those props are in bad shape, but you should be around 12% or so. Under 10% is really good. I would try another set of 32's to see if its your props.....I also think 15x32's 3 blades would be better props.
dreamboater is offline
Old 10-02-2006 | 07:30 AM
with my 15x32 labbed 3 blades 5000rpms puts me at 80 on the button, with my 14 1/2 x 30's @ 5000 rpms im at like 75-76 mph
Old 10-02-2006 | 08:53 AM
Just a thought, but could my motors be too high? Before someone asks, I don't know where they're at. How high should they be?
Mike
Old 10-02-2006 | 08:56 AM
in my opinion if they were to high it would be difficult to plane and would blow out as well...my PROP SHAFT CENTERS are 1 5/8's of an inch above the hull...
