Wide or narrow band air / fuel meter >
Old 10-02-2006 | 04:40 PM
Donzi502's Avatar
Default Wide or narrow band air / fuel meter
Guys do i need a wide band or narrow band air fuel meter to dial in my 454 Mag with a reprogrammed ecu, big cam and lots of porting. Where do you get them from as well. Thanks
Donzi502 is offline
Old 10-02-2006 | 07:02 PM
Default Re: Wide or narrow band air / fuel meter
Wide Band..
http://www.innovatemotorsports.com
TwinTurboStroker is offline
Old 10-02-2006 | 08:14 PM
Elite Marine's Avatar
Twinturbostroker is right!!
They work great. Just need a bung in your exhaust pipes or make a plate to go under your riser. Just remember, O2 sensors and water do not mix!!!
Elite Marine is offline
Old 10-02-2006 | 08:16 PM
Wide band.
Narrow band (or old conventional style) will only tell you rich or lean, nothing else. Some companies will try to sell you tuning systems using non-wideband sensors. They're junk, and will give you almost no useful info to tune by (they won't even tell you rich/lean if you're more than a few points off 14.7)
bcarpman is offline
Old 10-02-2006 | 08:22 PM
Mike Paula's Avatar
A/F sensor (wide band) is the only way to go. they are good from λ=.7 to λ=2.2 a Duel stage O2 is only accurate from λ=.9 to λ=1.05
Mike Paula is offline
Old 10-03-2006 | 05:55 AM
SB
Wide band !!!!
Standard are from the Flinstone ages..
SB is online now
Old 10-03-2006 | 02:59 PM
Mr Gadgets's Avatar
Charter Member #601
I am running the LC-1 from Innovate. Had problem with it and they replaced it, since then no problems. Still on the first O2 sensor as well. Even mounted it in the most wrong postion (6 o'clock).. I have it connected to my ECU and a dash gauge. I like it very much..
Mr Gadgets is offline
Andy
3
04-20-2008 08:42 PM
Andy
Wanted
0
04-12-2008 12:04 PM
kennyo
3
03-17-2008 10:48 PM
DPA
2
06-16-2007 07:43 PM
eliminatethis
23
10-27-2006 07:39 PM
